Penulis Topik: Pira CZ Stereo Encoder for FM broadcasting  (Dibaca 65103 kali)
« pada: Oktober 03, 2009, 11:06:44 AM »
This stereo encoder is a halfway between analogue and digital processing. It combines the best from both domains to provide high-quality and easy to build device. The sampling frequency used in this stereo encoder is 97 times (!!!) higher than the pilot tone frequency. This makes very easy to reject all spectral residues around the sampling frequency without affecting the main signal characteristics. Using of a microcontroller allows to build this stereo encoder with reduced part count and get excellent results in real operation.
This stereo encoder advisedly does not contain any preemphasis circuit. Remember the key fact: a compressor/limiter/clipper device must be always present between the preemphasis circuit and the stereo encoder or modulator. Only this configuration ensures loud sound without exceeding the maximum frequency deviation limit (75 kHz). The stereo encoder is designed to provide really good sound. This always needs to use the compressor/limiter/clipper device where the preemphasis is precisely assured. The Pira CZ Compressor/Limiter/Clipper is highly suitable for this task.
Basic block diagram:
Characteristics:
    * Signal overshooting prevention
    * Low noise and distortion
    * No adjust (only pilot tone level and output level)
    * High channel separation and spectral purity in common operation
    * RDS input and pilot sync. output makes easy to connect any RDS encoder
    * Microcomputer controlled, hex file provided for free
    * All parts are easy to buy (incl. crystal)
Supply voltage:    9-16 V (stabilized)
Quiescent supply current (12 V):    34 mA
Audio 19 kHz rejection:    40 dB
Channel separation at 1 kHz:    >55 dB (see details)
Subcarrier rejection:    >60 dB
Pilot sampling frequency:    1.843 MHz (19 kHz x 97)
Subcarrier sampling frequency:    1.843 MHz (38 kHz x 48.5)
Pilot sync. output:    TTL
Max. audio input voltage:    5 V pp (1.75 V rms)
Pilot tone level:    linear adjustable 0-0.5 V pp
Output voltage gain:    linear adjustable 0-1.5
Audio input impedance:    2000 ohm
RDS input impedance:    1000 ohm
MPX output impedance:    500 ohm
Pilot sync. output impedance:    10000 ohm
Signal-to-noise ratio:     >70 dB
Schematic diagram:
Part list:
U1-U3 - TLC272, TS272
U4, U5 - 74HC4053 (74HCT4053)
U6 - 7805
U7 - PIC18F1220-I/P with stereo.hex file inside
Y1 - Crystal 7.3728 MHz (7.372 MHz)
SW1 - Button
L1, L2 - Coil 15 mH (09P-153J)
RN1, RN2 - SIL resistor network 3x 1k (discrete, 6 pin)
C1, C2 - 47p (C)
C3, C4, C5, C9, C24, C33-C35 C37 - 100n (C)
C6 - 82p (C)
C7, C19, C20, C30, C31 - 270p (C)
C8, C11, C14, C22, C23 - 220u/10V (E)
C10, C21, C25, C32 - 560p (C)
C12, C36, C38, C39 - 100u/10V (E)
C13 - 470u/25V (E)
C15, C26, C40 - 22p (C)
C16, C27 - 2n7 (C)
C17, C28 - 4n7 (P, 5%)
C18, C29 - 10n (C)
R1, R24 - 20k (1%)
R2-R9, R30, R31, R38, R39, R49, R50 - 2k (1%)
R10 - 160k
R11 - 330k
R12, R16, R27-R29, R40-R42 - 39k
R13 - 82k
R14, R17, R18, R20, R21, R25, R32, R43 - 10k (1%)
R15, R26 - 1k
R19 - 470R
R33, R34, R44, R45 - 30k (1%)
R35, R46 - 16k (1%)
R36, R47 - 47R
R37, R48 - 680R
R22, R23 - Trimmer 5k
HEX file: stereo.zip (WDT: on, Osc.: HS PLL, MCLRE: RA5), version 2.0.
Suitable free PIC programmer is for example here: http://www.members.aon.at/electronics/pic/picpgm/. Actually Pira CZ does not provide the PIC programming, PCB nor complete kit sale for this device.
Adjusting elements description:
Pilot level adjustment: The pilot level should be set to 9 % of the total deviation (75 kHz), measured in peak-to-peak values. For example, if audio input level is 2 V pp, set the pilot tone level to 0.2 V pp (the adjustment is linear with the max. of about 0.5 V pp).
Output level (gain) adjustment tip: If possible, it's recommended to set high output level and adjust lower sensitivity on the transmitter/exciter rather than set low output level and adjust high sensitivity. This way gives getter S/N ratio. Is it clear?
Note: The output level adjustment has no effect on pilot-to-audio ratio.
Mode selection: Click and hold the button until the mode change is indicated by acoustic signal (number of beeps indicates the mode set). The device will remember the setting. Mode table:
Mode L-P            Pilot
1    +0 dB    0 deg.
2    mono
3    +0.05 dB    0 deg.
4    +0 dB    -4 deg.
5    +0 dB    +4 deg.
Mode 1 is the default and recommended. Mode 2 switches to monaural operation. Modes 3 to 5 can compensate transient characteristics in some cases and improve channel separation, but have no reason for nonspecialists.
PCB:
selengkapnya dapat di lihat disini :
Re:Pira CZ Stereo Encoder for FM broadcasting
« Jawab #1 pada: Oktober 04, 2009, 03:50:55 AM »
pak ganteng buat skema di atas cari xtalnya yang susah
di pasaran ada 4,864 MHz. 38000KHz. 456KHz.
« Edit Terakhir: Juli 03, 2011, 02:06:02 AM oleh lutfi »
« Jawab #2 pada: Oktober 05, 2009, 02:15:22 AM »
iya ya ... enak kali orang luar negri ne ... semua ada ... kita susah2 cari yang gituan .. tapi pak pengalaman teman2 saya ... kalo mo buat kristal itu ... beli aja kristal yang frekwensinya dibawah ... misal mo dibikin di 4mhz ... kita cari dibawah ntu . mis kristal 3.5 mhz ... trus bongkar ... dan diamplas ato di tipiskan lagi lempengan kristalnya ... sampe ke 4 mega .. cuma harus ada xtal meter kali pak ya :D ... ini saya denger2 dari pengalaman teman saia ajah ... kali aja bisa kan .. whai nut dicoba ??? dari barang2 seken ...
« Jawab #3 pada: Oktober 05, 2009, 02:50:12 PM »
alhamdullilah dapet pengetahuan baru!!! owh ternyata bisa toh pake cara gituan
yaach moga aja bermangfaat!!
Bushyetdah
« Jawab #4 pada: Oktober 06, 2009, 08:08:51 PM »
Kalo saya pake yang 16x oversampling, pake kristal 4,864 MHz sama IC 4066 8 buah, IC TL072 2 buah dan 10 buah IC yang nomernya udah diamplas/dihilangkan.
« Edit Terakhir: Oktober 06, 2009, 08:13:26 PM oleh Bushyetdah »
« Jawab #5 pada: Oktober 06, 2009, 08:48:44 PM »
saia dah coba juga tu ,.. Bushyetdah... tapi icnya pake mc3333 untuk op amp nya ... susah nyarinya :D padahal opamp doang hahahha
« Jawab #6 pada: Oktober 08, 2009, 04:06:52 AM »
4066 8 buah kayaknya bisa diganti pake 4067 klo terlalu banyak ic noise yang dihasilkan akan lebih besar!
Bushyetdah
« Jawab #7 pada: Oktober 09, 2009, 04:40:40 PM »
Ngak juga tu. Hasil yang paling noise malah kalo pake 1 ic 4066, kayaknya semakin tinggi oversamplingnya, dengan kualitas separasi stereo yang sama akan dihasilkan audio yang lebih keras saat dimonitor lewat radio (MPX sudah tanpa dilengkapi 56 kHz LPF lagi). Memang kalo pake 4053 akan lebih simple rangkaiannya (jumlah IC tinggal separonya) kata yang ngebuatin, cuma lagi kelebihan stok 4066 dari project MPX terdahulu.
« Jawab #8 pada: Oktober 09, 2009, 11:42:50 PM »
mana bagus kira2 4066 diganti dengan 4148 ...karena saia dulu dapet yang pake dioda ... cukup bagus ...
« Jawab #9 pada: Oktober 10, 2009, 11:36:05 PM »
Kebalik Bro ....,
kalau digosok lebih tipis,  frekwensinya ya tambah turun .......
lagi pula wah ... kalau digosok pakai amplas..., mungkin pertama di Indonesia. Yang mungkin biasanya pakai pasta yang dipakai oleh tukang kacamata itu lho .......
Itupun untuk kristal jadul, yang masih bisa dibuka tutupnya dengan sekrup. Dan gedhenya sebesar batterei 9 volt itu. Kristalnya khan cuma dijepit pakai per...
Lhah kalau kristal yang sekarang dan casingnya solderan itu .... wah coba aja deh .....
Eh.. threat ini apa ngga lebih cocok masuk di microcontroler yang seri PIC ya....?
« Edit Terakhir: Oktober 10, 2009, 11:40:29 PM oleh MARCONIST »
« Jawab #10 pada: Oktober 11, 2009, 04:48:15 AM »
owh jadi noise tertutup oleh suara yang dihasilkan lebih keras dari biasanya?
« Jawab #11 pada: Oktober 11, 2009, 04:56:23 AM »
pake 4184 bagus juga hehe stereo jadul :)!! tapi bagusan pake ic lebih complex!, stereo itumah ada di blognya pak ibrahim kalimantan!
www.geocities.com/inoor_9000/
Offline 4ND1K
  • Tulisan: 37
    • RADNET
« Jawab #12 pada: Oktober 11, 2009, 02:21:18 PM »
Kalo yang noise dari sumber audionya maka berapapun oversamplingnya tidak ada pengaruhnya. Karena noise MPX biasanya  berasal dari harmonisa/kelipatan ganjil dari frekuensi pilot 19 kHz juga bisa dari frekuensi 38 kHz.
Contohnya bisa dilihat sbb:
http://rbsfm.ej.am/joomla/index.php?option=com_content&task=view&id=523&Itemid=29
Contoh diatas adalah akibat dari harmonisa frekuensi 38 kHz. Dengan memperbanyak oversampling maka harmonisanya akan lebih sedikit. Jadi kita bisa menambah volume untuk dikirim (dengan indeks modulasi yang sama).
« Jawab #13 pada: Oktober 12, 2009, 02:30:36 AM »
pak tapi gag juga! stereio saya ada yang samplingnya rendah 2x kok noisenya mpx nya kecil hampir tak terdengar!! tapi ada juga setereo buatan temn saya dengan jumlah sampling yang sama noise mpx justru besar malah sampai terdengar suara........ssssssssst!! ketika kita menggunakan headphone!!...
klo di daerah saya hampir semua para breaker fm yang berlomba2 membuat stereo jadi mereka klo ngebrik suaranya stereo....dan saling pamer keunggulan stereo masing2 yang mereka buat !! hehe sudah tradisi di daerah saya! :)
« Edit Terakhir: Oktober 12, 2009, 02:35:53 AM oleh lutfi »
Offline 4ND1K
  • Tulisan: 37
    • RADNET
« Jawab #14 pada: Oktober 12, 2009, 08:57:10 AM »
Satu lagi faktor yg pengaruhnya besar adalah daya pancar efektif. Kalo mau fair cobanya pke pemancar yang sama, recevernya jg sama diletakkan agak jauh sampai sinyal mono hampir noise, baru mpx diadu.
 Baru kelihatan noise yg mana.
