Pemancar (Transmitter)
rdw8w pll
Halaman: [
Topik: rdw8w pll (Dibaca 7853 kali)
radium98
Oversea Member
Newbie
Tulisan: 32
rdw8w pll
pada:
Mei 24, 2012, 01:56:41 AM »
hello does anyone give this a try i made it and dont now why still unlock everything is ok this is the RDW 8w pll fm transmitter digital a help from expertz could be good help thanks mate i supplied my pictures transmitter with a file of all need to do one please help me
http://www.sendspace.com/file/azqj2a
< download link for complete project hope u will help me this time
Bubun Stupid
Full Member
Tulisan: 175
Re:rdw8w pll
Jawab #1 pada:
Mei 26, 2012, 11:15:02 AM »
Hello
radium98
dada2
had you firstly check VFO circuit in
stand-alone
mode ? (remove all control-connections to/from PLL circuit) then swap varactor diode from well source voltage. If you have frequency counter, check what is freq range out from VFO, is it in standard FM broadcast region ? or you can check by tuning VFO for make
zero beat
tone in neared standard FM radio receiver. If the procedure result works properly, you can check other malfunction at PLL circuit... cari1 ide1
radium98
Oversea Member
Newbie
Tulisan: 32
Re:rdw8w pll
Jawab #2 pada:
Juli 07, 2012, 10:56:10 PM »
hello again nice to see some help here from members.the transmitter now work but i have a strange problem that i have a difference of 100khz step exemple i put on transmitter 98.00 and i have on receiver 98.10 always a 100 khz step in difference i tried some extra capacitors value on legs of xtal 3.2 and same result i saw on frequency meter its about a 100 khz always if i put 98.05 on tx i have on receiver 98.15 mhz any help please from expertz
isurG_
Isurganteng
Tulisan: 2683
Keseharianku Melawan Waktu
Re:rdw8w pll
Jawab #3 pada:
Juli 08, 2012, 01:13:56 AM »
could be a mistake in pic assembler, or make sure the reference frequency, may be overstate the capacity pf trimmer, if there is to use the frequency counter for the reference output
radium98
Oversea Member
Newbie
Tulisan: 32
Re:rdw8w pll
Jawab #4 pada:
Juli 20, 2012, 10:05:42 PM »
salam again the pll work now ok but have little problem , can someone share hex file for both 16f628 and 16f84a they said same hex will work for both ic but it didnt
other question how can i put my name at start because i see someone can put his name
thanks
geetings guys
isurG_
Isurganteng
Tulisan: 2683
Re:rdw8w pll
Jawab #5 pada:
Juli 28, 2012, 11:47:22 PM »
ic pic to differ 84a & 628a, for 2x16 and 1x16 lcd hex is different, including the use xtal 6.4 and 3.2, to change your name should be changed to the assembler, then compiled it to hex, I try to use software proton deploment suite,
gluiermo marconi
Tulisan: 434
IKHLAS...
Re:rdw8w pll
Jawab #6 pada:
Desember 27, 2012, 06:01:26 PM »
hmmmm...cunfused...no idea...
Halaman: [
rdw8w pll
