Penulis Topik: MPX Stereo With AVR Microontroller  (Dibaca 28705 kali)
« pada: Oktober 03, 2009, 11:01:09 AM »
A Simple FM Stereo Transmitter
using an AVR microcontroller.
A very simple stereo encoder that produces good channel separation yet requires only an
inexpensive microcontroller and a few passive components.
Find updates at www.projects.cappels.org
This project appeared in the December, 2007 issue of  Info Elektronika Magazine.
Notice: Before operating a radio transmitter, find out what kind of transmitter operation, if any, is permitted in your locality. Radio transmitter operation is a serious legal matter. In the United States, operation of unlicensed intentional radiators is covered by Part 15 of Title 47 of the Code of Federal Regulations. This design can be readily adapted to different frequencies and different power levels. If you choose to build and operate the transmitter described here, you do so at your own risk. I'm only publishing this as an example of what can be done.
Photo 1. In the picture above,
The parts to the right of the green capacitor are the FM radio transmitter.
The parts between the 8 pin DIP and the transmitter are the resistor matrix.
One capacitor, C5, is mounted on the back of the board, and one other capacitor,
C11, had not yet been installed. It was later installed just below the 560k resistor.
The connector in the upper-left is the unregulated power input. The connector in the
 lower middle is audio input. ATTINY12, ATTINY25, and AT90S2323 were tested on this board
while the ATTINY2313 and AT90S2313 were tested in another breadboard.
download hex nya silahkan disini
Re:MPX Stereo With AVR Microontroller
« Jawab #1 pada: Oktober 03, 2009, 06:33:23 PM »
Stereo Micro :)  kreatif
« Edit Terakhir: Oktober 03, 2009, 06:39:40 PM oleh lutfi »
« Jawab #2 pada: Oktober 03, 2009, 06:36:13 PM »
tampilin dong .... kalo bisa yang samplingnya gueeedeee ....
« Jawab #3 pada: Oktober 03, 2009, 06:42:49 PM »
wew lgi online toh! pak ganteng!!
mf pak! saya agak lancang comment diatas! jadi saya ubah!!
www.katruud.nl
ada skema 16xsampling
« Edit Terakhir: Oktober 03, 2009, 06:46:29 PM oleh lutfi »
« Jawab #4 pada: Oktober 03, 2009, 06:50:06 PM »
gila tu KatRuud FA30 Stereocoder.
tampilin aja pak .. biar yang lain ngga susah2 buka .... ngomong2 tu xtal nya gampang tak ?
« Jawab #5 pada: Oktober 03, 2009, 06:53:25 PM »
8x sampling stereo coder ada di
www.phantomfm.nl
« Edit Terakhir: Oktober 03, 2009, 07:02:45 PM oleh lutfi »
« Jawab #6 pada: Oktober 03, 2009, 07:03:25 PM »
links skemanya dimana ya ? apa tak ada ... ?
« Jawab #7 pada: Oktober 03, 2009, 07:11:04 PM »
ampundah internetnya lemoot mf agak lama yaach !!
www.broadcasthardware.blogspot.com
« Jawab #8 pada: Oktober 04, 2009, 03:41:07 AM »
« Jawab #9 pada: Oktober 05, 2009, 02:20:59 AM »
kayanya saia pernah beli stereo koder model gini deh ... sia beli 200 an ... mang bagus si ...
« Jawab #10 pada: Oktober 05, 2009, 02:24:16 AM »
wadoh ... iki gambar skema stereo avr kok kadang2 jadi gambar gugug ya ... ngga rela kali di share ne.... :D
« Jawab #11 pada: Oktober 05, 2009, 02:51:49 PM »
serverna ada virusnya kali!! :)
omngesex
« Jawab #12 pada: Oktober 06, 2009, 11:08:48 AM »
pak sur member baru saya ni. pak sur segala macam pemancar FM yang mono kalau di kasih Stereo Enkoder itu apa bisa jadi stereo ya?......
Bushyetdah
« Jawab #13 pada: Oktober 06, 2009, 08:26:53 PM »
Kalo dah pake mikrokontroler kepala bisa pusing, padahal cuma liat bahasa asemblynya.
« Jawab #14 pada: Oktober 06, 2009, 08:47:14 PM »
itu kan hex nya dah ada ... tiggal dimasukin aja dalam ic ... (padahal ane lom coba input2 hex intel .,,)sok teu kali ye,,,... hahahhahaha
kalgo pemancar mono dikasi stereo ya pasti idup ....
