Penulis Topik: 100w rf power amplifier  (Dibaca 26587 kali)
Offline radium98
  • Oversea Member
  • Tulisan: 32
« pada: Agustus 10, 2010, 01:18:27 PM »
HI this is a 100w rf power amplifier original design BROADCAST warehouse ,  and i want to share with u :)
R1, R2 1 ohm/ 1/2 watt, karbon
R3 15 ohm/ 1/4 watt karbon
C1, C2, C12 10nf, keramik
C3 36pf, silver mica
C4 22pf, 15pf keramik diparalel kapasitor variable 25pf
C5 60pf, kapasitor variable (plastik)
C6 1nf, keramik
C7 34pf, 22pf, 15pf kermik diparalel
C8 15pf, kermaik
C9, C10 15pf, silver mika 250v
C11 120pf, kapasitor variable
L1, L3 Tembaga 1 mm, diameter 5 mm, 3 lilit
L2 Tembaga 1.2 mm, diameter 5 mm, 3 lilit
L4, L5 Tembaga 1 mm, diameter 5 mm, 6 lilit
FB1, FB2,FB3 2 Ferrite bit diseri
FB4, FB5 1 Ferrite beat (6 lubang), dililit tembaga 1 mm sebanyak 2 lilit
i need some help with this anyone help me with the size of that 5 w veronica pcb thanks
« Edit Terakhir: Agustus 11, 2010, 12:12:07 AM oleh isurganteng »
Re:100w rf power amplifier
« Jawab #1 pada: Agustus 10, 2010, 02:12:10 PM »
Dulu saya pernah bikin seperti ini, tetapi sayang sekali gagal.
Kayaknya nggak jodoh saya sama 2782 :d
Salam,
Offline widyo
  • Tulisan: 79
    • Hobby Radio & Elektronika
« Jawab #2 pada: Agustus 11, 2010, 10:33:35 PM »
In fact this design created by Indonesian people named: Ibrahim Noor. You can see his archieve in http://www.oocities.com/inoor_9000/
Offline radium98
  • Oversea Member
  • Tulisan: 32
« Jawab #3 pada: Agustus 12, 2010, 12:14:23 AM »
no widyo it's not his desighn it;s a uk broadcast warehouse old 100 watts design using blf244 mosfet and sd1407 npn 100w
http://img228.imageshack.us/img228/6435/30072010327.jpg
he makes modifications only i have had made his design i will upload soon anyone can help i need size of 5 w up
Offline radium98
  • Oversea Member
  • Tulisan: 32
« Jawab #4 pada: Agustus 12, 2010, 12:59:09 PM »
 :D @ Marine this is the 100w amplifier in 3 different version
ibrahim noor version , radium98 and broadcast warehouse original , look at them .
http://img153.imageshack.us/g/12082010333.jpg/
http://img148.imageshack.us/img148/5373/transmitterfm125w5.jpg
enjoy.
garciass gathool
« Jawab #5 pada: Agustus 12, 2010, 01:42:31 PM »
ya sudah.kalau ini sih memang produk warehouse.dan memang bang Ahim memang salah satu referensinya dari warehouse.lihat pada pemasangan trimer condensator dekat output rakitan bang Ahim.kan tidak orisinil sesuai desain asli pcbnya.but,by the way.no problema..........!
« Jawab #6 pada: Februari 11, 2011, 12:40:20 PM »
Kalo ini gimana?? gak pake trimer.. mantap... awet... adem.. inputnya macth
« Edit Terakhir: Februari 22, 2011, 08:06:35 AM oleh jeckoexxel »
Offline roxas
  • Tulisan: 124
« Jawab #7 pada: Februari 20, 2011, 07:09:35 PM »
2SC2782 di datasheet buat 80 Watt, kalau hasil test sheet memang bisa lebih dari 100 Watt. tapi biasanya kalau buat dipakai pemancar yang kontinue on air lebih baik jangan lebih dari 80 Watt, biar awet
Offline abine khonsa
  • Tulisan: 5
« Jawab #8 pada: Maret 04, 2011, 10:25:08 AM »
mau tanya nih saya kan beli rangkaian pemancar FM 10mWatt trus  bisa gx untuk nendang rangkaian penguat sinyal RF 100watt ini??kalo bisa dan ada yg mau menjualnya saya ingin beli.maklum nubi..... ^_^ atau jika ada yang tahu solusinya????
« Jawab #9 pada: Maret 04, 2011, 10:41:25 AM »
Waduh jauh banget yah ? paling tidak butuh Power input 20 watt an buat nge drive 100 watts..
10 mW  ? ni ngak salah tulis ....
« Jawab #10 pada: Maret 04, 2011, 11:05:44 AM »
kang jack bagi donk layoutnya...pengen nyoba pake 2630..... drop1
  • Tulisan: 5
« Jawab #11 pada: Maret 04, 2011, 01:16:46 PM »
[/quote]
iya bener mas,itu gx salah nulis.emang belinya yg segitu.mas bisa ngadain kit PA 20Watt yg bisa ditendang dgn inputan daya 10mili volt ini.atau ada solusi lain? ^_^
  • Tulisan: 5
« Jawab #12 pada: Maret 04, 2011, 01:18:15 PM »
upss...maaf maksudnya bukan 10 milli volt tp 10 milli watt....   :-D
« Jawab #13 pada: Maret 04, 2011, 01:49:21 PM »
paling tidak membutuhkan 4 kali penguatan neh baru kuat ndorong 100Watt
« Jawab #14 pada: Maret 04, 2011, 02:02:24 PM »
Ada Skema dan Lay Out nya.. bagi2 donk.  cari1
