Penulis Topik: 150 Watts BLF177  (Dibaca 36607 kali)
Offline new_bie
  • Tulisan: 96
Re:150 Watts BLF177
« Jawab #15 pada: Desember 27, 2010, 10:11:51 PM »
Bagus...
Sudah saya coba rangkaian ini dan berhasil
BLF177 sy beli dari broadcastconcepts, tegangan 45V (adjust 48V) 4 amp
Output 150watt. Input  2-3 watt
Pak mahmud jual kit ini gak? harga berapa?
Re:150 Watts BLF177
« Jawab #16 pada: Januari 02, 2011, 01:09:11 PM »
rakit sendiri aja modal 1,2jt dah jadi
Re:150 Watts BLF177
« Jawab #17 pada: Januari 02, 2011, 03:26:28 PM »
 8) 8) sippp
Offline mbah bams
Re:150 Watts BLF177
« Jawab #18 pada: Maret 18, 2011, 10:05:24 AM »
ada yg jual nggak palet yg udah jadi aku mau beli hub mendutfm@yahoo.com 085366575758
Re:150 Watts BLF177
« Jawab #19 pada: Maret 18, 2011, 10:12:08 AM »
Ada stok yang ini 1 buah saja, asli produk broadcast concepts
link http://www.broadcastconcepts.com/index.php?main_page=product_info&cPath=1&products_id=3
kalau butuh pm ke saya
Designed for FM radio transmitters, this amplifier incorporates broadband matching and a BLF177 MOSFET transistor.
    * 86 – 110MHz.
    * 50 Volts.
    * Input/output 50 ohms.
    * Pout: 145W minimum***
    * 16dB Gain (150W)
    * Class B.
    * 4:1 output coax transformer.
    * Requires up to 4.0 watts of input drive for maximum output power.
    * Requires 48 to 50Vdc at 4.5 amps typical.
    * -14dB input return loss or better.
# Please read everything including the data sheet before placing your order.
# This new design incorporates a 4:1 broadband coaxial transformer matching scheme. The result is high efficiency and improved frequency response.
# We also added diode temperature compensated bias for enhanced performance over temperature.
# New bias disable pads facilitate integration into amplifier systems that employ automatic VSWR protection. Taking this pad to ground will shut down the amplifier.
# Click here to view more detailed image of the amplifier. This picture is 250kb jpg format.
# Please download the amplifier data sheet in PDF format (260kb). The data sheet contains detailed performance information and operator instructions.
# Mechanical information is available in DXF Fromat or PDF format.
# Each pallet amplifier we sell is tested on an HP 8753D vector network analyzer.
# This amplifier is capable of 150 watts.
# Our amplifier products use ATC/AVX microwave chip caps for high reliability.
# This pallet is optimized for 48 volt operation. Using a lower voltage will result in poor efficiency and significantly lower output power; however, 28 volt operation is possible.
# We sell a high quality 500 watt low pass filter for FM broadcast applications.
Low pass filternya juga ada yang seperti ini asli juga produk broadcast concepts
Re:150 Watts BLF177
« Jawab #20 pada: Maret 18, 2011, 10:18:01 AM »
Pak Mamud LPF ini misal di pakai di bawah 500watt apa langsung bisa.. misal 50-100watt  konek1
Re:150 Watts BLF177
« Jawab #21 pada: Maret 18, 2011, 10:21:49 AM »
Hanya untuk maksimum 150watt saja.
Re:150 Watts BLF177
« Jawab #22 pada: Maret 18, 2011, 10:23:13 AM »
lha itu tulisan'nya ko 500watt  ::)
Re:150 Watts BLF177
« Jawab #23 pada: Maret 18, 2011, 10:29:41 AM »
Kalau diatas 150watt capasitornya pakai metal clad dan kawat emailnya lebih besar.
ini untuk 500watt
Ini biasa saya pakai untuk mosfet 1kw
Re:150 Watts BLF177
« Jawab #24 pada: Maret 27, 2011, 10:02:33 AM »
wih wih ngiler lihat penampakan barang bagus  drop1
Re:150 Watts BLF177
« Jawab #25 pada: Agustus 13, 2011, 03:34:33 PM »
Saya mau coba BLF 177 tapi saya masih ragu tentang fenel yg ada di tmpat saya tman2 mgkin bisa bantu apakah fenel ini benar2 BLF177
kalau yg di bawah ini sepertinya saya agak yakin kalau satu pabrik seharusnya sama persis
Offline Edy
  • Tulisan: 23
  • kanan kiri ok
Re:150 Watts BLF177
« Jawab #26 pada: Agustus 22, 2011, 10:11:03 AM »
Kl yang pake segel Plastik tu asli pa nggak BUNG RIO / YANG PUNYA DJ FM ?http://elektronika.web.id/elkav2/Smileys/new2/corong.gifhttp://elektronika.web.id/elkav2/Smileys/new2/cari.gifhttp://elektronika.web.id/elkav2/Smileys/new2/kalkulasi.gifhttp://elektronika.web.id/elkav2/Smileys/new2/drop1.gifhttp://elektronika.web.id/elkav2/Smileys/new2/drop1.gif
Offline Edy
  • Tulisan: 23
  • kanan kiri ok
Re:150 Watts BLF177
« Jawab #27 pada: Agustus 25, 2011, 10:24:25 AM »
Bgmana BUNG Rio yang Pya DJ FM jadi Buat BLF177 ngak ?/ sekalian BLF578XR no mbledozz no matching no konzlet no problemmm Piye piyee ? ?  ;D :'( :'( drop2 drop2 drop2 boys1 boys1 boys1 boys1 boys1 boys1 top1 top1 top1 top1 top1 tampar1 tampar1 :-[ :-[ :-[ ninja1 ninja1 ninja1 ninja1 ninja1 .
Kalo 2782x4 boyoss skrg Rp 300Rb, Blf177 kmrn Beli 500rb, PCB belum saya buatt, Pilih NXP/rdvv ?tp kok input tu 8Watt aopa gak Mbledozzz, pdhal datashett 2-3wattt dahhh kebul2x hantu2 hantu2 hantu2 kelahi1 kelahi1 kelahi1 kelahi1 kelahi1 :-[ :-[ :-[ :-[ :-[
Re:150 Watts BLF177
« Jawab #28 pada: Agustus 25, 2011, 10:53:47 AM »
seharusnya masuk sini aja dulu bung Edy.. http://elektronika.web.id/elkav2/index.php?topic=14.885
Offline Edy
  • Tulisan: 23
  • kanan kiri ok
Re:150 Watts BLF177
« Jawab #29 pada: Agustus 25, 2011, 11:35:25 AM »
dAFTAR dah 2th yang lalu baru kenalan yaa BUNG RIO yang py DJ FM 97.5 Mhzz Sambeng Klatenn  aplos1 aplos1 aplos1 aplos1 aplos1 aplos1 aplos1
