Penulis Topik: PLL - digital tuning from Pira  (Dibaca 22728 kali)
« pada: Juni 07, 2010, 09:23:13 PM »
Technical specifications:
Dual-speed PLL designed for wideband FM transmitter.
Power supply: 8-15 V stabilized, 40 mA
Frequency range: 82,5-108 MHz
Step frequency: 100 kHz
RF input voltage range: 10-500 mV
RF input impedance: 135 ohm
Schematic diagram:
Pin meaning:
1 - tuning voltage (output)
3 - RF signal from oscillator (input)
2, 4 - ground
Tl1 - reset
Parts list:
Capacitors:
C1, C12 - 2,2 nF (ceramic)
C2, C9 - 10 nF (ceramic)
C3 - 47 uF (electrolytic)
C4 - 10 uF (tantalum)
C5 - 0,47 uF (electrolytic)
C6, C11 - 100 nF (ceramic)
C7 - 1 nF (ceramic)
C8 - 220 uF (electrolytic)
C10 - 22 pF (ceramic)
Resistors:
R1 - 1k
R2 - 4k7
R3, R4, R5, R7 - 10k
R6 - 1k (optional)
R8 - 47k (optional, see below)
Misc.:
IC1 - SAA1057
IC2 - PIC16F84 (programmed) + socket
IC3 - 78L05
X1 - 4 MHz crystal
D1 - LED diode (optional)
Tl1 - button (optional)
jumpers or DIP switches
Software for the IC2:
pll16f84.asm : http://pira.cz/pll16f84.asm  pll16f84.hex : http://pira.cz/pll16f84.hex
Oscillator type: RC, watchdog: ON.
Jumpers/DIP switches setting: see pllfreq.txt : http://pira.cz/pllfreq.txt
or download user-friendly program! : http://pira.cz/pllset.zip
Instructions
The Tl1 button resets the unit. Press it after frequency set. The unit provides a reset on power-up, so you don't need to use the button.
The D1 LED indicates the tuning cycle is done (after one second from reset). It's not needed to use it and the R6 resistor.
The R8 resistor provides a minimal voltage of about 2 V on the PLL output. Use this resistor if the transmitter's oscillator doesn't work if the tunning voltage is below this value (mainly after power-up). Place the resistor over the R3.
Notes:
Output of the PLL should not be directly loaded with big capacities (over about 0,3 uF). The PLL loop may be unstable. This applies to some unknown transmitters.
PCB layout :
source : www.pira.cz
« Edit Terakhir: Juni 08, 2010, 11:10:54 AM oleh Sinur »
Re:PLL - digital tuning
« Jawab #1 pada: Juni 07, 2010, 09:36:03 PM »
PLL ini sudah lama ada di pira tetaoi kelihatnnya kurang menarik.
Walau saya sudah punya SAA1057 males ngerakitnya dan beralih ke
PLL yang pakai LCD untuk percobaannya.
Offline tuvixxx
  • Tulisan: 120
« Jawab #2 pada: Juni 07, 2010, 09:45:30 PM »
om... untuk vco yg bs di gabungkan dengan pll apakah semua jenis vco bisa om..., asalkan yg menggunakan dioda varaktor.... apa begitu om...???
« Jawab #3 pada: Juni 07, 2010, 09:58:45 PM »
Karena masih belajar, jadi buat yang single band dulu pak.... dan yang penting simple.... :)
Sebenar nya lg pusing jg nich....pengen buat PLL IC na tinggal pasang ga usah pake progaram-2 man kaya PIC dll________ Tapi audio nya diatas ( setara ) dgn Exiter Veronika.
Downloader PIC nya ja belum jadi -jadi  :-\
( CURHAT MODE : ON )
« Jawab #4 pada: September 26, 2010, 01:53:24 PM »
mangnya ada link-nya om sinur... kayaknya tertarik juga nih.....
Offline pinarakmas
  • Tulisan: 16
Re:PLL - digital tuning from Pira
« Jawab #5 pada: Mei 05, 2011, 02:01:13 PM »
 cari1 cari1...kelanjutannya gimana..sudah ada yg ber hasil..newbie menunggu..... hallo1 hallo1 hallo1
Tessssssssttttttttttttttt......................................................................................
« Jawab #6 pada: Mei 05, 2011, 09:53:53 PM »
Pengalaman saya dari beberapa teman yang make digital PLL, malah mereka minta kembali ke model TC 9122, disamping gak pernah rewel.. gak usah mikir kalo IC err.. atau blank.. emang tampilan kurang keren.. paling display cuman sebagai assesories saja.. tapi awetnya  itu yang bikin kesengsem... gak mikir service lagi.. asal proteksinya bagus...
Saya pakai TC 9122-LB 3500-4060.. malah banyak yang suka... maaf gak bisa share.. saya gak bs gambar skema + PCB pake kompie.. biasanya suruhan org... itupun malah lay out yg dari spidol di pindah ke kompi... gak repot2 lagi...
« Jawab #7 pada: Mei 05, 2011, 10:00:03 PM »
« Jawab #8 pada: Mei 26, 2020, 11:18:35 AM »
yang udah pernah nyoba di share donk  ;D
pcb udah di gambar ulang, tinggal nyetak neh.....
