Penulis Topik: 1 GHz Counter from pira  (Dibaca 39300 kali)
« pada: Mei 27, 2010, 11:25:13 AM »
This simple counter is useful for frequency measurements of various wireless equipments, especially transmitters, receivers and signal generators in VHF/UHF band.
Features :
Display range: 0,0 to 999,9 MHz, resolution 0,1 MHz
Correct rounding, reduced blinking of last digit
Over-range indication
Fast measurement - short measuring period
High input sensitivity in VHF/UHF band
Switchable intermediate frequency offset for use with receiver
Technical specifications :
Supply voltage: 8-20 V
Supply current: typ. 80 mA, max. 120 mA
Input sensitivity: max. 10 mV in 70-1000 MHz range
Measuring period: 0,082 sec.
Display refresh rate: 49 Hz
Schematic diagram :
Parts list
R1 - 39 k
R2 - 1 k
R3-R6 - 2,2 k
R7-R14 - 220
C1, C5, C6 - 100 n mini
C2, C3, C4 - 1 n
C7 - 100 u
C8, C9 - 22 p
IC1 - 7805
IC2 - SAB6456 (U813BS - different pin layout, not tested, also maybe R1 value need to be changed)
IC3 - PIC16F84A programmed + socket
T1 - BC546B
T2-T5 - BC556B
D1, D2 - BAT41 (BAR19) - may be ommited
D3 - HD-M514RD (red) or HD-M512RD (green), 4-digits multiplex driven LED display from HP, or four standard 1-digit LED displays
X1 - 4.000 MHz crystal
BNC input connector
To use with a receiver as a digital scale, close the -10,7 pins.
IC3 program download: countr.hex http://pira.cz/counter.hex
Programmer settings: Oscillator: XT, WDT: on
For additional changes (eg. IF frequency offset change): counter.asm http://pira.cz/counter.asm
The SAB6456 description :
The SAB6456 is a prescaler for UHF/VHF tuners. The circuit has an input frequency range of 70 MHz to 1 GHz, has high input sensitivity and good harmonic suppression. With lower sensitivity it's usable down to 3 MHz.
The circuit comprises an input amplifier, a divider stage and an output stage. The divider stage may oscillate during no-signal conditions but this oscillation is suppressed when input signals are received. The voltage-edges of the output signals are slowed internally to reduce harmonics in the television intermediate frequency band.
Kepada temen-2 yg pernah membuat frequensi counter ini, tolong disharing pengalaman dan saran nya. Soalnya aku lg coba buat. ( supaya bisa meminimalisir kesalahan dan buget tentunya  ;D )
Salam.....
Offline RADIO-SEMPRONG
  • Tulisan: 129
Re:1 GHz Counter from pira
« Jawab #1 pada: Juli 26, 2010, 12:32:02 PM »
Prescalernya tu lho.. Carinya dimana??
« Jawab #2 pada: Juli 26, 2010, 12:37:39 PM »
Marconi glodok siap bantu , tp harga nya...... ?? .???
Aku mentok di PIC nya...
« Jawab #3 pada: Juli 26, 2010, 10:34:02 PM »
PIC16F84A banyak juga di toko beng elektronik glodok !,...
« Jawab #4 pada: Juli 27, 2010, 12:34:01 AM »
Bukan IC nya pak , tp downloader nya yg bemasalah. Gagal baca error , terus..... ..nyampe aku buat 2 buah RCD , eh ternyata com / DB 9... Mb ku rusak.... ..
« Jawab #5 pada: Juli 27, 2010, 02:56:48 AM »
oooo dikirain..... kalo cuma MB rusak mah banyak bro pentium 3 ato 4 yg bekas masih bagus2 di harco mangga dua !,....pentium 3 dibawah 100rb an pentium 4 150rb keatas....
Offline aljero
  • Tulisan: 270
« Jawab #6 pada: Juli 27, 2010, 08:05:09 AM »
saya juga kebngungan carinya
« Jawab #7 pada: Juli 27, 2010, 08:39:26 AM »
Marconi & hermes glodok siap bantu mencari.... ?.. ? Tp harga spesial. Kalo ngambil @5 pcs mungkin harga bs turun... .. he....he.. Belum tanya lg sich...
  • Tulisan: 129
« Jawab #8 pada: Juli 27, 2010, 03:30:00 PM »
SAB6456 di ebay kira2 USD10 blm ongkir.. Mahal tuh.. Sy pernah denger 74F112 2 biji bs dijadiin prescaler 10 ya? Ada yg pernah coba? Soalnya kalo pake ini lebih irit, lumayan kan kalo bisa dipake sampai 300mhz..
« Jawab #9 pada: Juli 27, 2010, 03:48:45 PM »
kalau prescalernya diganti pake lb 3500 bisa ndak ya???? ::)
  • Tulisan: 129
« Jawab #10 pada: Juli 27, 2010, 07:21:15 PM »
Emang lb3500 msh ada di pasaran? Kalo ga salah ic tsb devider 8..
« Jawab #11 pada: Oktober 23, 2010, 06:13:50 AM »
sulit juga ya cari komponennya.... :-[
« Jawab #12 pada: Januari 23, 2011, 12:16:06 PM »
saya kurang tertarik frekuensi counter dengan PIC meskipun bisa ringkas banget.
« Jawab #13 pada: Januari 23, 2011, 01:39:43 PM »
klo macem ini,.......tertarik ndak ya,..... ide1,
« Jawab #14 pada: Januari 23, 2011, 02:09:58 PM »
lha ini swr power meter + frek counter jadi satu tambah ruwet tambah ga tertarik.klo tinggal pakai nah itu lain ai hi hi hi
