Penulis Topik: pemancar stereo bh1417 1chip + pll  (Dibaca 30430 kali)
Re:pemancar stereo bh1417 1chip + pll
« Jawab #15 pada: Januari 28, 2010, 03:55:41 PM »
:D
Gan minta daftar harga dunks
sekalian klo ama aksesorisnya semuanya brapa tuh....
trims berat gan sebelumnya
 ;D
Coba lihat di WARUNG MARKONAH
Offline macross
  • Tulisan: 39
  • I Am The Lone Fighter
« Jawab #16 pada: Januari 28, 2010, 07:06:57 PM »
Salam...
Mbok Markonah
harganya 60rb ya......
BTW ini tokonya ada di surabaya ya....
trims infonya kang ato mbok.....
Offline STL
  • Oversea Member
  • Tulisan: 114
« Jawab #17 pada: Februari 11, 2010, 06:40:34 PM »
In Thailand, priced at 500 baht. No selling. I used instead of BA1404. use BA1404 to noise. Stereo only. Not a transmitter.How to edit.
Thank you  very much.
     STL
 Thailand
« Jawab #18 pada: Februari 11, 2010, 09:58:35 PM »
     STL
 Thailand
Make sure that Oscillator (at pin no. 10) really work, use oscilloscope or other methods, then check the output at pin. no. 7 ....
500 baht equivalent with Indonesian Rupiah about 141.000,-     wow..... !
here at my local shop the price about 60.000 IRD or  212 Baht
Regards
Offline STL
  • Oversea Member
  • Tulisan: 114
« Jawab #19 pada: Februari 15, 2010, 11:29:41 AM »
chek then,  is OSC , Change the MPX. Work no problem.  Thank you.
The money.Indo-Thai for the expensive or more expensive. Thailand's currency is lower than much of the USA. Equipment is expensive.
                   STL
« Jawab #20 pada: Februari 15, 2010, 02:08:10 PM »
masi kaga mudeng2 ne  :'( use dollar amrik aja lah biar standar .. tau mana yang mahal hwhewhe
« Jawab #21 pada: Februari 17, 2010, 10:35:44 AM »
Kalo gasalah IC BH1417 PLL nya hanya bisa nyampe ( 87.7 s/d 88.9 ) dan (106.7 s/d 107.9 ) jadi gabisa set PLL di ( 89.0 s/d 106.6 )
http://electronics-diy.com/BH1417_PLL_Stereo_FM_Transmitter.php
Offline STL
  • Oversea Member
  • Tulisan: 114
« Jawab #22 pada: Februari 17, 2010, 03:40:54 PM »
Hello  all
 isurganteng ,  I do not know the same.  Specialty no money.
And thanks , purwanto-amm .....That information.  I have no right to use this IC number.
Thailand does not sell.  ha  ha  ha .... BA1404 used instead.
Terima kasih  banyak.
   STL
« Jawab #23 pada: Februari 17, 2010, 04:29:23 PM »
Hello  all
   STL
Rupiah, Baht, Dollar this is just money. It just pieces of metal coin or or sheet op paper ...........!
But the problem would come if we have no money. although it just a pieces of metal/paper ...!
Everthing you can buy.
Just one that you can not buy : ............ TIME  .............. !
« Jawab #24 pada: Juni 09, 2010, 02:03:03 AM »
itu biasanya bisa di dapet di pemancar fm untuk mobil ... kalo dibuka isinya biasanya  BH1415 BH1417 dsb ... kalo yang pake 1415 ... ntu b isa ditambah pic .. untuk digital dan lcd ... simpel si ... buat pcbnya .. ic na kezil bbangeddd pake smd ...
yang dimobil kaya gini ya http://www.quangadget.com/images/200907/1248744045559177253.jpg
Offline VPDX
  • Tulisan: 184
    • MARS TEAM
« Jawab #25 pada: Juni 09, 2010, 09:56:04 PM »
Nih aku dah dapat modulator fm mobile harganya cuma 55rb frekuensinya bisa di set dari 87.7-107.9 Mhz tingal pencet dari remot ato dr modulatornya langsung,sudah ada slot flasdisk dan memori card tinggal pasang langsung bunyi.........
Sayangnya modulatorku ngak bisa lock di 87.5 Mhz padahal frekuensi yg tersisa cuma segitu doang......
I LOVE ELEKTRONIKA
« Jawab #26 pada: Juni 11, 2010, 02:38:48 PM »
sama bro... ini  gak bisa dilock......
ahirnnya di ut pengunci frekwensinya tak bikin dari pake timer IC 555 atur delay-nya biar pas ;D yang penting bisa ngunci ... di 107,8 Mhz
audionya lumayan...
« Jawab #27 pada: Juni 11, 2010, 02:49:56 PM »
relay pada timer digunakan untuk switch pada pengatur freqwensi
timer diatur sesuai freq yang kita inginin
jangan di ketawain ya ide konyol ini ..... hahaha... haaa ;)
tolong kalo ada solusi yang lain?
« Jawab #28 pada: Juni 19, 2010, 12:32:35 AM »
kreatip .. lanjutkan ...
Offline widyo
    • Hobby Radio & Elektronika
« Jawab #29 pada: Juli 13, 2010, 10:24:39 PM »
kenapa ga bisa? pake penguat kelas A tr nya 2sc2570, 2sc930
Mas Lutfi.. mohon bisa kasih contoh skema penguat dgn transistor2 tsb nya.
Trims sebelumnya.
