Penulis Topik: Modified RDVV & CCA or RVR  (Dibaca 7380 kali)
Offline Oneng
  • Tulisan: 19
« pada: April 14, 2011, 06:52:51 PM »
I was build and modified between RDVV and RVR.
Output of this exciter only for 300mW.
How to do it :
     1). You need to design PCB by own PLL RDVV check and download on internet.
     2).  Then see the manual of RVR build oscillator till final of exciter, U don't have
           please just contact me a schematic of RVR I will share for U.
     3). Also U can build with CCA, CCA oscillator is very simple then RVR.
          U don't have too, again just contact me I will give a link for download.
Mate, Exciter is very simple but most people problem, they no have a measurement test and also don't know how to starting or begining.
If U now the procedure to build up FM Transmitter so U can get a result.
 drop1
But most people hobbies in electronic transmitter don't now how to programme or written the code of basic-asm-c or c++
 drop1 bete1 bete1 bete1 bete1 bete1 bete1 bete1 drop1
Enjoy......
Cheers.
Oneng.
Offline bayu01
  • Tulisan: 218
Re:Modified RDVV & CCA or RVR
« Jawab #1 pada: April 14, 2011, 07:24:35 PM »
Hi Oneng .....I'm interested with your topics here lope.....please open your design and share with us mohon1....as I know in this forum PLL RDVV already open to discussion see http://elektronika.web.id/elkav2/index.php?topic=1156.0.
You are right without test measurement not easy top1 that's way we open this forum to share our experiences and knowledge to minimize fault.......regarding a software to build a telecommunication circuit so far I don't to fine a good one....can you give us for that? mohon1
Offline Oneng
  • Tulisan: 19
« Jawab #2 pada: April 15, 2011, 09:48:47 PM »
Hi Bayu,
Next time I will share to U on this forum, right now I am not at home.
I worked as an analyst software engineer at oil company in holland, at this time I am at platform Nord Sea, far away from U.
Since 2002 th, I was build RDVV and CCA-RVR, my background are telecommunication engineering and also software programming deep on C++.
I was worked as a chief engineer at 1997 in Jakarta, but less money so I go expand to abroad.
 kalkulasi1
This my tip for U,
 ide1
U Build oscillator RVR including stage of power amplifier at exciter, firstly do not use PLL, U just injection or put the source of voltage with little power supplies 0-10 Volt, check your counter might U oscillator exciter working they have any signal, for inductor at RVR U made just 3 turn with enamel +/- 0.6mm-0.8mm.
Ensure the oscillator working properly since U give a source voltage.
Used for transistor of oscillator J310 or U310, this transistor very well working, important for U note, U should have measurement test such as
frequency counter-VSWR-Dummy Load this is minimal but better U have oscilloscope or spectrum analyzer but to expensive for U ....well, remember hobbies incomplete for these measurement test.
Finish U build RVR, U design PLL from RDVV I think the schematic spread in an internet ....
I still love to build but so long time I am not create a design lay-out of PLL, is't a old for me but ......many people still love.
Mate, I started with building CB - 80-100 Meter with tube and solid state - AM.
I think so many people right here still love to experiment PLL,  from newbie and pro.
Cheers,
Oneng.
