Penulis Topik: RADUGA FOR TELEVISION & VIDEO v3.9.5 RELEASED  (Dibaca 16693 kali)
« pada: Oktober 07, 2009, 12:23:56 AM »
Raduga's NEW VIDEO Features
It's time to be excited.  By popular demand we have just released our NEW VIDEO PLUS Version of Raduga (version 3.9.5).  Raduga now does all popular formats of video with the same ease as you've experienced with our audio only versions.  As to what kind of video formats it can play, there is one simple answer.  If Windows Media Player can play it, so can Raduga 3.9.5!  It's so easy to set up.  Simply install [2] separate video cards in your system (the output video card to the secondary monitor must have an S-Video output jack), fire up your PC and place Raduga Software in the Master monitor.  The first time you play a video a small video window will appear on your screen.  Simply drag it over to the secondary monitor and double-click its center.  The video window will appear full screen and stay that way.  In between videos, the background will stay black.  You control the output video monitor window via Raduga from the master screen.  Composite video output available via the S-Video output jack and a composite adaptor that usually comes with most video cards.  That's it!
New in Version 3.9.5
    * Online Registration Bug Fixed
    * Bugfix: Overlap with a previous audio file, video will not automatically close
Streaming STL Software Via TCP/IP
NEW! AirLink STL RX & TX v1.1.1900
Transmit your Studio audio to the Transmitter Tower site dependably, affordably.  No Wireless STL transmitters to purchase, no frequencies to coordinate, no licenses to apply for, no antennas to install or position.
AirLink's Story
Here's the scenario.  Your transmitter is 5 miles from your studio.  So how do you get your audio from the studio to the transmitter without the hassles and expenses?  Let us introduce the new AirLink STL.  AirLink consists of a Software Audio Transmitter and Receiver.  The transmitter is installed at the studio and the receiver installed at the remote transmitter site.  Then all you need is a PC at each end and either a high speed internet or ISDN connection at each end.  AirLink uses the TCP/IP protocol to transmit your audio and it is very reliable.
So what if your internet connection is lost and the audio stream stops?  The receiver portion of AirLink STL is very very smart.  It will constantly monitor and wait for your stream to reconnect.  But while your connection is lost, the AirLink STL Receiver will begin playing local audio files that have been pre-loaded injecting a liner or sweep after XX number of songs and let's not forget your Legal ID at the top of the hour.  This is done easily by a mini automation system that is incorporated in the receiver.  When AirLink STL detects that your stream has returned reliably for 30 seconds it will resume the connection to your studio automatically.
AirLink STL Features
    * Simple and easy set up
    * Plays local music files if connection is lost with it's own mini automation system
    * Plays local liner/sweep files after every xx song, if connection is lost
    * Plays your top of the hour, Legal ID's as required by the FCC
    * NEW Low Cost - Receiver only $125 each and Transmitter only $200 each
    * Feed multiple stations with one transmitter and multiple receivers
    * Great for networks!
    * Works with Raduga Automation Software
« Edit Terakhir: Oktober 07, 2009, 12:26:27 AM oleh isurganteng »
Re:RADUGA FOR TELEVISION & VIDEO v3.9.5 RELEASED
« Jawab #1 pada: Oktober 08, 2009, 03:51:03 AM »
klo raduga kayaknya tampilannya mirip sapa zararadio yaach!!!
sanggar
« Jawab #2 pada: Oktober 08, 2009, 08:41:52 AM »
Downloadnya gimana? Full plus crack atau cuma trial/demo?. Makasih Boss atas infonya.
« Jawab #3 pada: Juni 30, 2010, 09:30:33 AM »
Akum.......
Mas Izur Ganteng......... mo tanya, adakah link download RADUGA FOR TELEVISION & VIDEO v3.9.5 RELEASED
cz masih newbie........ sebelum dan sesudahnya matur nuhun........
« Edit Terakhir: Oktober 22, 2010, 10:09:44 PM oleh achsan »
« Jawab #4 pada: Juni 30, 2010, 11:23:08 AM »
Kalau tak salah etika di forum ini tidak diperbolehkan memberikan informasi mengenai
bajakan software termasuk crack dan serial number. Arti kata lain usahakan sendiri crack/
serial number tsb dan dipakai sendiri tanpa ada orang yang tahu.
* Tidak menyertakan hal-hal berbau "Bajakan", "Hack", "Crack", "Keygen" atau sejenisnya, jika toh terpaksa harus dilakukan, sampaikan melalui PM atau eMail http://elektronika.web.id/elkav2/index.php?topic=141.0
« Jawab #5 pada: Oktober 22, 2010, 10:11:08 PM »
ok bos siap laksanakan perintah......
« Jawab #6 pada: Desember 09, 2010, 09:12:09 AM »
raduga?! adda di kompi saya raduga kalo menurut saya suara maknyus  8) di banding sama zarra yang sudah di tambahi bbp(trial) msih imbang" saja suaranya, malah saya rasa lebih warm raduga, mungkin ada pandapat laen?
« Jawab #7 pada: Desember 09, 2010, 12:08:49 PM »
lwbih suka radio boss sama winamp :D :-* :-* :-*
Offline Benny-pku
  • Tulisan: 95
« Jawab #8 pada: Januari 12, 2011, 10:27:36 AM »
klu saya sich lebih enak pake WinAMP..
« Jawab #9 pada: Januari 12, 2011, 11:07:12 AM »
bikin dong bos untuk plugin winamp na ...
« Jawab #10 pada: Januari 12, 2011, 12:02:44 PM »
iya sama,,,saya lebih senang pake radioboss,,,soalny gak beli,,,yg beli boss  konek1
« Jawab #11 pada: Januari 12, 2011, 12:09:59 PM »
coba trial aja .... tapi basik yang free mantepan winamp hahahha pake skin yang 2006 model radiobos juga ehheeh ...
« Jawab #12 pada: Januari 12, 2011, 12:38:22 PM »
kalo aku biasa pakai jetAudio  ide1
« Jawab #13 pada: Januari 12, 2011, 12:58:58 PM »
sebenarnya penasaran dengan AirLink STL biasanya berbasis ip pasti ada delay ...
