Penulis Topik: RADIO AUTOMATION SOFTWARE - BROADCAST POWER BP2X  (Dibaca 12388 kali)
« pada: Oktober 05, 2009, 11:11:48 PM »
Broadcast Power Features
Broadcast Power is now at version 2.5.5.8
With the upgraded Broadcast Power, 2.5.1 we completely changed the user interface.
Instead of a dockable tabbed interface with a top menu, we have chosen to use a RibbonMenu with buttons. Each button displays a specific part or aspect of the application, shielding you from all others. This simplifies your user experiences and focuses your attention on the task on hand.
Searching for a specific functionality is now easier as the RibbonMenu has its items grouped in a logical manner.
Also, our installer now has been slashed in size; it's smaller and better. The installer does not attempt to create the database schema, instead, we have placed this functionality within the application.
Many of the error messages have been modified and made more readable with, where possible, suggestions for solving the error.
Best of all, it's now completely free. A new Broadcast Power License was written for Broadcast Power.
Now you can:
# Play audio on 2 devices from the same application (Main device and PFL device)
# Mix multiple audio files on the same device using software mixing
# Control the same playback and change data from multiple computers
# Control the same playback and change data over the internet without special configurations to your firewall
# Define cue points on audio files to use for automation mixing: Start, Intro, Outro, Mix In, and Mix Out
# View and playback news and news clips
# Publish currently playing media data to a website using plugins
# Activate Line-In functionality during playback
# Web streaming to Shoutcast or Oddcast
# Allows you to write or use thrid party plugins to enhance its funcationality
# Limit user access with enhanced security and finer access control
# Get detailed exception or error logs from the event viewer
# Redirect exception and error logging to a file, email address, and other stores
# Control more than a single station feed from the one user interface with a click of a button using our ingenious remote player controller engine, provided all controlled player executables are connected through a network and are reachable to the controller
# Schedule your programs in a hierarchical structure
# Schedule commercials and campaigns in three different methods giving you flexibility
# Schedule programs visually using a multi track editor
# Automate volumes on individual occurences of an audio within a program or schedule
# With a click of a button fully automate the playback and audio selection
# Control audio selection using rule based algorithms and settings
# Playback audio and view their status through either the volume control, progress bar, or graphical audio frequency visualization
# Work with the application in either assisted or automated modes
# Scale up from a free database engine (MSDE or SQL Server 2005 Express) to a full fledged SQL Server 2000 or SQL Server 2005 database
# Integrated reporting engine
# Change the user interface language on the fly or by pre-configuring (subject to language and translation availability)
# Plugins support for the user interface and server engine
# Finally, enjoy a rugged, robust and intelligent radio automation and management system
Offline dxdiag
  • Tulisan: 205
Re:RADIO AUTOMATION SOFTWARE - BROADCAST POWER BP2X
« Jawab #1 pada: Desember 03, 2009, 04:37:14 PM »
ini software gunanya buata apa ya? maklum gak bisa bhs inggris, tolong dijelasin pake bahasa nasional aja om... tanks
« Jawab #2 pada: Desember 12, 2009, 11:50:11 AM »
NIH TAK BANTU TERJEMAHANYA
Broadcast Power Fitur
Broadcast Power sekarang pada versi 2.5.5.8
Dengan upgrade Broadcast Power, 2.5.1 kita benar-benar mengubah user interface.
Alih-alih sebuah antarmuka tab dockable dengan menu paling atas, kita telah memilih menggunakan RibbonMenu dengan tombol. Setiap tombol menampilkan bagian tertentu atau aspek dari aplikasi, melindungi Anda dari semua orang lain. Ini menyederhanakan pengalaman pengguna Anda dan memusatkan perhatian Anda pada tugas di tangan.
Mencari fungsionalitas tertentu kini lebih mudah sebagai RibbonMenu memiliki item yang dikelompokkan dalam cara yang logis.
Juga, installer sekarang kami telah diiris dalam ukuran; lebih kecil dan lebih baik. Installer tidak berusaha untuk membuat skema database, alih-alih, kita telah menempatkan fungsi ini dalam aplikasi.
Banyak dari pesan kesalahan telah dimodifikasi dan dibuat lebih mudah dibaca dengan, dimana mungkin, saran untuk menyelesaikan kesalahan.
Terbaik dari semua, sekarang benar-benar gratis. Broadcast baru Power Lisensi ini ditulis untuk Broadcast Power.
Sekarang Anda dapat:
# Play audio di 2 perangkat dari aplikasi yang sama (perangkat utama dan perangkat PFL)
# Mix beberapa file audio pada perangkat yang sama dengan menggunakan perangkat lunak pencampuran
# Kontrol pemutaran yang sama dan mengubah data dari beberapa komputer
# Kontrol pemutaran yang sama dan mengubah data melalui internet tanpa konfigurasi khusus untuk firewall
# Tentukan isyarat poin pada file audio yang akan digunakan untuk otomatisasi pencampuran: Mulai, Intro, Outro, Mix Dalam, dan Mix Out
# Lihat dan pemutaran klip berita dan berita
# Publish media sedang diputar data ke situs web dengan menggunakan plugin
# Aktifkan Line-In fungsionalitas selama pemutaran
# Web streaming ke Shoutcast atau Oddcast
# Memungkinkan Anda untuk menulis atau menggunakan plugin pihak ketiga untuk meningkatkan funcationality
# Batasi akses pengguna dengan keamanan yang ditingkatkan dan kontrol akses lebih halus
# Dapatkan rinci pengecualian atau error log dari acara penampil
# Redirect pengecualian dan kesalahan logging ke file, alamat email, dan toko-toko lain
# Control lebih dari satu stasiun feed dari satu antarmuka pengguna dengan mengklik tombol remote cerdik menggunakan kontrol pemutar mesin, asalkan semua pemain dikontrol executable yang terhubung melalui jaringan dan terjangkau untuk controller
# Jadwal program-program anda dalam struktur hirarki
# Jadwal iklan dan kampanye dalam tiga metode yang berbeda memberikan Anda fleksibilitas
# Jadwal program visual menggunakan editor multi lagu
# Otomatis volume pada setiap kejadian dari audio dalam program atau jadwal
# Dengan mengklik tombol mengotomatisasikan sepenuhnya dan audio pemutaran seleksi
# Control seleksi audio menggunakan algoritma berbasis aturan dan pengaturan
# Playback audio dan melihat status mereka melalui salah satu kontrol volume, progress bar, atau frekuensi audio visualisasi grafis
# Bekerja dengan aplikasi baik dalam dibantu atau mode otomatis
# Skala naik dari database gratis mesin (MSDE atau SQL Server 2005 Express) untuk matang penuh SQL Server 2000 atau SQL Server 2005 database
# Terpadu mesin pelaporan
# Ubah bahasa antarmuka pengguna secara on the fly atau dengan pra-konfigurasi (tergantung pada terjemahan bahasa dan ketersediaan)
# Plugins dukungan untuk antarmuka pengguna dan server mesin
# Akhirnya, menikmati kasar, kuat dan cerdas radio otomasi dan sistem manajemen
« Jawab #3 pada: Desember 23, 2009, 12:30:59 AM »
mantab bapak ne bisa translit .. ngga dari google translate kan ? hwhewhehw
« Jawab #4 pada: Desember 23, 2009, 09:24:34 AM »
ya ne kang dari google translat ne tinggal copy paste doang
« Jawab #5 pada: Desember 23, 2009, 10:38:32 PM »
Ini software utk apa ya?
Udah di dunlud tp ga bisa masangnya...
Masangnya harus konek internet ya?
Klo direttore ma zara enak, biz pasang langsung play!
Bingung bener ma BP2X...
« Jawab #6 pada: Desember 23, 2009, 11:54:08 PM »
iya .. kemarin saia juga instal gitu ... ada yang harus diminta file2 lain dari microsoft ... jadi ngga segampang install yang laen ...
« Jawab #7 pada: Januari 06, 2010, 02:27:50 AM »
perlu di coba neh! pengen tau bagusan mana sama sam!
Offline Amron
  • Tulisan: 67
« Jawab #8 pada: Januari 06, 2010, 03:01:44 PM »
Nah lo kok sama ya  ;D ;D ;D saya juga gitu  :D
« Jawab #9 pada: Januari 06, 2010, 09:53:50 PM »
kayanya ngga ada masalah kalo windows na lisen ... hahahhaha
