Penulis Topik: OSCILLATOR DUAL GATE MOSFET  (Dibaca 17624 kali)
« pada: Oktober 04, 2010, 04:51:56 PM »
kalo mo buat osc yang stabil gunakan mospet dual gate ...
http://site.mynet.com/piracz/ostr/ostr9.htm
« Edit Terakhir: November 04, 2010, 06:35:07 AM oleh isurganteng »
Re:OSCILLATOR DUAL GATE MOSFET
« Jawab #1 pada: Oktober 04, 2010, 05:22:31 PM »
sip om...saya copas dulu skemanya, mumpung masih ada 1 BF960 dikulkas...
tapi klo pake FET, keseringan bikin pake 2SK192 sih...ini juga stabil dibanding pake BJT...
btw, list spare part-nya mana om???  ???
« Jawab #2 pada: Oktober 04, 2010, 05:34:03 PM »
ntu kan ada link na ....
« Jawab #3 pada: Oktober 04, 2010, 05:41:27 PM »
oh iya...barangkali aja link nya down, kan masih ada backup disini om... ;D
« Jawab #4 pada: Oktober 04, 2010, 05:47:58 PM »
ndak ah ... idup kok ......
Instead of the BF900, a BF905, BF907 or BF961 can be used without any
problems. Maybe a BF981 would do also, but that I haven't tested.
COMPONENT LIST
Resistors:
(All resistors are metalfilm types except R1 which is a carbon resistor)
R1 :  47k, 1/8 W      R5 : 220k, 1/8 W
R2 :  47k, 1/8 W      R6 : 100k, 1/8 W
R3 :  47k, 1/8 W      R7 : 150E, 1/8 W
R4 : 100E, 1/8 W      R8 : 10k, lin. pot
Capacitors:
C1: 100 nF Multilayer or ceramic   C8 :   1 nF ceramic
C2: 4.7 pF ceramic         C9 :   1 nF ceramic
C3: 100 nF ceramic         C10: 100 nF ceramic
     (1 or 10 nF will do also)      C11: 100 nF ceramic
C4:  40 pf trimmer         C12: 100 nF ceramic
C5: 4.7 pF ceramic         C13:  47 uF/25V
C6:  10 pF ceramic         C14:   1 nF ceramic
C7:  22 pF ceramic
Inductors:
L1 : 4 wdg, dia 8 mm, 1 mm CuAg, space 1 mm;
     Mounted 8 mm above PCB (Leads are 4 mm)
L2 : 6-hole ferroxcube wideband HF-choke (5 wdg)
L3 : 6-hole ferroxcube wideband HF-choke (5 wdg)
Others:
Q1 : BF900
D1 : BB405,BB102 or equal (most varicaps with C = 2-20 pF (approx) will do)
U1 : uA78L08, uA7809, uA7810 or equal (MC78LXX, UC78LXX etc)
« Jawab #5 pada: Oktober 04, 2010, 06:44:12 PM »
sip dah om ganteng... ijin copas ya.....
Offline ranggaokta
« Jawab #6 pada: Oktober 31, 2010, 01:44:00 PM »
Bang Isur Tolong di jelasin induktornya,L1,L2,L3..
Maklum gak ngerti inggris  :)
« Jawab #7 pada: November 01, 2010, 08:50:40 AM »
sangat membantu sekali penjelasannya...... om ganteng...... :-*
« Jawab #8 pada: November 01, 2010, 09:38:03 AM »
L1 : 4 lilit diameter koker 8mm, kawat 1mm spasi 1mm
L2 : 5 lilit pada toroid kawat 0,6mm
L3 : idem
toroit pake seperti teman2 ngambil dari lampu hemat energi ... ada tu didalamnya ....
Offline ranggaokta
« Jawab #9 pada: November 04, 2010, 06:24:14 AM »
terima kasih banyak bang isur yg ganteng  ;)
« Jawab #10 pada: November 04, 2010, 07:52:43 AM »
Nemu di Majalah ELEKTOR Juli/Agustus Tahun 1983, Tapi sayang bahasa-nya ga ngerti :'(
Offline kang cevi
  • Tulisan: 4
« Jawab #11 pada: November 21, 2010, 05:37:19 AM »
ok juga untuk dcoba,nanti saya bandingkan dengan osc fet 192,
Offline demas08
  • Tulisan: 7
« Jawab #12 pada: November 16, 2011, 05:49:38 PM »
pak linknya mati..... boleh dikirim gambarnya ke email saya??
RF never die
« Jawab #13 pada: November 16, 2011, 07:03:34 PM »
nih ada link lainnya mas...semoga sama
http://www.frn.net/tech/xmitters/fm/bf900/
 hallo1
« Jawab #14 pada: November 17, 2011, 04:20:16 PM »
Colpitts nya yang bikin manstab... hampir sama dengan kebiasaanku pake Colpitts.. tapi mungkin ngga langsung bisa 20 MHz kalo di gandeng PLL.. mesti dimodif/eksperiment sendiri spy lebar...
