Penulis Topik: Power Amplifier FM 150Watt 2X 2SC2782 2SC2694 2SC2630 2SC1946  (Dibaca 130694 kali)
Re:Power Amplifier FM 150Watt 2X 2SC2782 2SC2694 2SC2630 2SC1946
« Jawab #15 pada: Januari 09, 2010, 09:14:22 PM »
mang asli ntu bu ,,,... sampe 2 ke eamil saia ....
Offline Amron
  • Tulisan: 67
« Jawab #16 pada: Januari 09, 2010, 09:52:36 PM »
mas mau tanya neh dari input bosster ke output driver itu pake apa kabel ya nah yang saya tanya panjang kabel jumpernya perlu di hitung ngak? n rumusnya bagaimana trims maklum newbie ;D ;D
javon
« Jawab #17 pada: Januari 09, 2010, 10:21:10 PM »
hello, drawn components on the PCB do not match the  sch .....
you have photos of the real amplifier with 2x 2sc2782
« Edit Terakhir: Januari 09, 2010, 11:19:28 PM oleh javon »
« Jawab #18 pada: Januari 10, 2010, 05:17:46 PM »
Komponen yang di gambar di PCB tidak cocok dengan schematicnya,
Hayoo.... Hayoo...., siapa yang bisa bantu dengan gambar (photo) asli dari amplifier ini ya...
Tolong bantu nih warga jauh kita .....
« Jawab #19 pada: Januari 10, 2010, 07:58:15 PM »
From some PM from "Javon", I try to observe and understand this PCB. I admit that I am less interested in the PA transistors, so I do not ever comment on the matter. Finally I understand why Javon to wonder: "Where's the picture of this amplifier in the real world? "
Since the PCB and the image does not match
Javon was indeed true, that the PCB is hiding some elements of incongruity.
Look at this image:
Ternyata Basis dan Emittornya terkoneksi (Gandeng).... Wah......
While other drawn:
Please try to look closer, The  FeriteBead (written under the name Ferrit Beat  ;D) I think placing it in reverse with the Schema also Feedthrough Capacitor (written under the name : C Feed Throught) How to install?
Please forgive me if I'm wrong because my understanding of this PCB model is not enough.
It was also learned for me, especially when writing the component with wrong term.
Well I'm somewhat embarrassed  :-[ , I was less rigorous,
CMIW
Are there  additional comments?
mujur... mujur ... untung ada google translate .... ;D
« Edit Terakhir: Januari 10, 2010, 08:29:36 PM oleh MARCONIST »
« Jawab #20 pada: Januari 10, 2010, 10:34:02 PM »
ini lah akibat pahamnya main jimplak2 ... kaga ngarti dengan komponen ... padahal kalo mau juga ntu di pake pcbnya ... tinggal atur skala perbandingan print aja sama komponent nya ... maunya real2 aja cemplak bikin ... jadi ... coba ... duaaaaaaarrrrrr ... baik banget markonist dah mo tunjukin ...
temen saia aja disini ada yang minta boster skema 1946 dia buat terbalik2 pcbnya sampe mpletus ... 1946 ... yah .. .ntah lah ... kapan mo pintar kalo mo jiplak2 mulu ...
Offline one101
  • Tulisan: 5
« Jawab #21 pada: Januari 22, 2010, 10:25:29 PM »
kalau saya kemarin berhasil kok bikin pcb dan saya coba  ouput nya terahkir 190 watt pakai 2782 kalau bisa transistor nya kedua dua masih baru.......untuk pcb nya di edit dulu mas pake program photoshop.. dan buat file yg sudah di edit pake format jpeg , copy gambar yg di simpan dlm bentuk jpeg ke microsoft word .pcb  untuk ukuran nya ikut print  nya pd words td,sesudah ukuran nyata di atas kertas .jangan lupa ukur besaran fisik transistor sampai pas gambar nya.  untuk layout pcb nya saya masih punya, cuma untuk up load nya susah di masuk kan ke forum ini.saya coba2 up load nya tidak bisa tampil alias gagal. oke selamat mencoba semoga berhasil............ ;D ;D ;D ;D ;D ;D ;D
« Jawab #22 pada: Januari 23, 2010, 01:10:25 AM »
upload nya di www.flickr.com aja mas ... saia disana .. lagi pula terintegrasi dengan email ...
na ne sebagai contoh .... berhasil kan ??? makanya tong jiplak waeeeeeeee ....
kreatip dong dikit   >:(
« Jawab #23 pada: Januari 24, 2010, 10:57:27 PM »
dapet ne pcb tuk 2x 2782 atawa 2694 ... dulu pernah buat ne ...
skema saia rasa sama2 sajah ......
Offline STL
  • Oversea Member
  • Tulisan: 114
« Jawab #24 pada: Februari 11, 2010, 06:44:55 PM »
Circuit this....Use with Mosfet BLF278  or not.  Thank you.....    :'(
« Jawab #25 pada: Februari 11, 2010, 08:52:38 PM »
no this circuit specially for 2SC2694, 2SC2630, 2SC2782 not use for BLF278 RF Power mosfet
thanks
Lutfi
Offline STL
  • Oversea Member
  • Tulisan: 114
« Jawab #26 pada: Februari 15, 2010, 09:45:01 AM »
Thank you  very much.
      STL
« Jawab #27 pada: Februari 15, 2010, 03:47:21 PM »
for example look at the picture !
Offline STL
  • Oversea Member
  • Tulisan: 114
« Jawab #28 pada: Februari 16, 2010, 02:17:28 PM »
 ;D   Thank you ......    ;D
    STL
Offline VPDX
  • Tulisan: 184
    • MARS TEAM
« Jawab #29 pada: April 04, 2010, 01:33:02 PM »
ada yang punya gak skema PA 50W pake C2630?... soalnya ini saya disuruh bikinin PA 50w ma temen. sebelumnya saya pake 2X C1946. maksut saya ini dari pada pake 2X C1946 kan lebih praktis pake C2630.
kalau ada tolong posting segera ya saya tunggu
There is a 50W PA scheme using C2630? ... this because I was told to make the same PA 50W friends. before I use 2X C1946. This from the use 2X's more practical C1946 using C2630.
if yes please post soon I wait
gimana cara memparalel c1946?........Trus skemanya gimana?..........Apa demikian juga bisa di aplikasikan pada c1970 <memparalel c1970>?.............
I LOVE ELEKTRONIKA
