Penulis Topik: SUBROUTINE 8 bit x 16 bit = 32 bit  (Dibaca 15695 kali)
Offline Iman Fushshilat
« pada: Januari 09, 2011, 01:24:36 AM »
permisi, mau minta tolong.
Barang kali ada yang punya subroutin perkalian 8 bit dengan 16 bit yang
mana hasil lebar data maksimalnya mampu 32 bit (8 bit x 16 bit = 32
bit)
saya udah coba nyari2 di internet dan menemukan beberapa cuma hasilnya
kurang memuaskan (tidak benar) .
contoh ini:
; subroutine MUL816
; 8-Bit x 16-Bit to 32-Bit Product signed Multiply
; 2's Complement format
; input:    r0 = multiplicand X
;           r3, r2 = multiplier Y
; output:   r3, r2, r1, r0 = product P = X x Y (r3 = sign extension)
; calls:    Cr0, Cr2r3, Mr0r3
; alters:   acc, C, Bits SignX & SignY
MUL816:        push    b
               anl     PSW, #0E7H      ; Register Bank 0
               acall   Cr0             ; 2's comp -> Mag/Sign
               acall   Cr2r3           ; 2's comp -> Mag/Sign
               mov     a, r0           ; load X low byte into acc
               mov     b, r2           ; load Y low byte into B
               mul     ab              ; multiply
               push    acc             ; stack result low byte
               push    b               ; stack result high byte
               mov     a, r0           ; load X into acc again
               mov     b, r3           ; load Y high byte into B
               mul     ab              ; multiply
               pop     00H             ; recall X*YL high byte
               add     a, r0           ; add X*YL high and X*YH low
               mov     r1, a           ; save result
               clr     a               ; clear accumulator
               addc    a, b            ; a = b + carry flag
               mov     r2, a           ; save result
               pop     00H             ; get low result
               mov     r3, #0
               acall   Mr0r3           ; Mag/Sign -> 2's Comp
               pop     b
               ret
; subroutine Cr0
; 8-Bit 2's Complement -> magnitude / Sign Bit Conversion
; input:     r0 = signed byte
; output:    r0 = magnitude
;            Bit 21H = sign (21H is set if r0 is a negative number)
; alters:    acc
Cr0:           mov     a, r0           ; read X into accumulator
               jb      acc.7, Cr0a     ; X is negative if bit 7 is 1
               clr     SignX             ; clear sign bit if 'positive'
               ret                     ; done
Cr0a:          cpl     a               ; X negative, find abs value
               inc     a               ; XA = complement(XT)+1
               mov     r0, a           ; save magnitude
               setb    SignX             ; set sign bit if 'negative'
               ret
; subroutine Cr2r3
; 16-Bit 2's Complement -> magnitude / Sign Bit Conversion
; input:    r3, r2 = signed word
; output:   r3, r2 = magnitude
;           Bit 22H = sign (22H is set if negative number)
; alters:   acc, C
Cr2r3:         mov     a, r3           ; read high into accumulator
               jb      acc.7, c1a      ; negative if bit 7 is 1
               clr     SignY             ; clear sign bit if 'positive'
               ret                     ; done
c1a:           setb    SignY             ; set sign flag
               mov     a, r2           ; number is negative
               cpl     a               ; complement
               add     a, #1           ; and add +1
               mov     r2, a
               mov     a, r3           ; get next byte
               cpl     a               ; complement
               addc    a, #0
               mov     r3, a
               ret
; subroutine Mr0r3
; 32-Bit magnitude / Sign Bit -> 2's Complement Conversion
; input:    r3, r2, r1, r0 = magnitude
;           Bits 21H & 22H = sign bits of operands X and Y
;           (set if negative)
; output:   r3, r2, r1, r0 = signed word
; alters:   acc, C
Mr0r3:         jb      SignX, Mr0r3b     ; test X sign
               jb      SignY, Mr0r3a     ; test Y sign
               ret
Mr0r3b:        jnb     SignY, Mr0r3a
               ret
Mr0r3a:        mov     a, r0           ; negate number
               cpl     a               ; complement
               mov     r0, a
               mov     a, r1           ; get next byte
               cpl     a               ; complement
               addc    a, #0
               mov     r1, a
               mov     a, r2           ; get next byte
               cpl     a               ; complement
               addc    a, #0
               mov     r2, a
               cpl     a               ; complement
               addc    a, #0
               mov     r3, a
               ret                     ; done
nah ini revisi yang agak baru dari sang penulis program (W.G.Marshall)
tapi tetep masih belum benar juga.
; subroutine MUL816
; alters:   acc, C, r4, Bits SignX & SignY
MUL816:        push    b
               mov     b, r2           ; load Y low into B
               mul     ab              ; multiply
               xch     a, r0           ; save X*YL low, reload X
               mov     r4, b           ; temp save X*YL high
               mov     b, r3           ; load Y high into B
               mul     ab              ; multiply
               add     a, r4           ; add X*YL high and X*YH low
               clr     a
               addc    a, b            ; X*YH high + 0 + carry flag
               mov     r3, #0          ; MS result = 0
               pop     b
               ret
; subroutine Cr0
;            Bit SignX = sign (SignX is set if r0 is a negative number)
; alters:
Cr0:           xch      a, r0          ; read X into accumulator
               clr      SignX          ; clear sign flag
               jnb      acc.7, Cr0a    ; X is negative if bit 7 is 1
               inc      a              ; X = complement(X)+1
               setb     SignX          ; set sign flag
Cr0a:          xch      a, r0          ; save magnitude
               ret
; subroutine Cr2r3
;           Bit SignY = sign (SignY is set if negative number)
; alters:   acc, C
Cr2r3:         mov     a, r3
               clr     SignY           ; clear sign flag
               jnb     acc.7, C1a      ; high byte negative?
               xch     a, r2           ; number is negative
               cpl     a               ; complement
               xch     a, r2           ; get MS byte
               cpl     a               ; complement
               addc    a, #0
               mov     r3, a
C1a:           ret
; subroutine Mr0r3
;           Bits SignX & SignY = sign bits of operands X and Y
;           (set if negative)
; alters:   acc, C
               ret
               ret
               cpl     a               ; complement
               mov     r0, a
               cpl     a               ; complement
               addc    a, #0
               mov     r1, a
               cpl     a               ; complement
               addc    a, #0
               mov     r2, a
               cpl     a               ; complement
               addc    a, #0
               mov     r3, a
               ret                     ; done
terima kasih
Re:SUBROUTINE 8 bit x 16 bit = 32 bit
« Jawab #1 pada: Januari 09, 2011, 01:43:00 AM »
lieur.......ane bantu sundul atas permintaan yg bikin topik
sundul sundul
« Jawab #2 pada: Januari 09, 2011, 01:51:09 AM »
sundul sundul
nuhun :-)
« Jawab #3 pada: Januari 09, 2011, 10:00:13 AM »
para pakar bantuin donk.....om dian,om risam,om juhar, mas herlambang, om busan...& boss ganteng
« Jawab #4 pada: Januari 09, 2011, 10:50:36 AM »
wah sy gagerti asembler, biasanya saya ngeprogram mikrokontroler pake Mikro-C yg lebih mudah  :-\  :-\
« Jawab #5 pada: Januari 09, 2011, 11:34:39 AM »
wah...sayang sekali
saya malah nga ngerti bahasa C, saya ngerti nya cuma Assambler Doang itu pun cuma buat MCS-51 ( maklum pemula banget)
Terim kasih mas purwanto
« Jawab #6 pada: Januari 17, 2011, 09:01:24 PM »
Waduh.. kemana nih para pakar? corong1
Offline M Joe
  • Tulisan: 11
« Jawab #7 pada: Maret 23, 2011, 01:11:54 AM »
Lho taunya klo gak bener di uji bagaimana..... aku pernah punya...  ide1 coba saya cari lagi  cari1 sabar ya.... sambil saya coba dulu. kalkulasi1 entar kalo udah saya coba post di sini. Kalo bisa pakai program C emang lebih gampang sih....
« Jawab #8 pada: Maret 23, 2011, 06:42:14 AM »
kalo di microC/microBasic/microPascal ada yg namanya data type ato jenis variabel mulai yg size nya kecil 1bit sampe 32bit
Kode: [Pilih]
bit 1–bit 0 or 1
sbit 1–bit 0 or 1
byte,char 8–bit 0 .. 255
short 8–bit -127 .. 128
word 16–bit 0 .. 65535
integer 16–bit -32768 .. 32767
longword 32–bit 0 .. 4294967295
longint 32–bit -2147483648 .. 2147483647
float 32–bit ±1.17549435082 * 10-38 .. ±6.80564774407 * 1038
jadi variabel-variabel tersebut bisa lagsung di +, -, * dan /, tanpa harus ada subroutin.... khusus
Offline M Joe
  • Tulisan: 11
« Jawab #9 pada: Maret 24, 2011, 01:01:13 AM »
Coba saya jawab ini saya bikin sendiri aja cari-cari ndak ketemu:
sedikit betulkan pertanyaannya ya.... 8 bit  x 16 bit hasilnya maximum 24 bit
contohnya kita kalikan aja nilai 8bit terbesar adalah FF  dan 16 bit terbesar FFFF
FF x FFFF = FEFF01     nah hasilnya khan 24 bit.....
procedure yg saya bikin ini digunakan mengalikan nilai 16 bit pada DPTR dan nilai 8 BIT pada R0
hasilnya di simpan di R1,R2,R3
jika dptr di isi    FFFF
dan r0 di isi          FF
maka hasilnya r1=FE
                        r2=FF
                        r3=01
mul16x8:
   MOV A,R0
   MOV B,dpl
   MUL AB
   MOV r3,A
   MOV r2,B
   MOV A,R0
   MOV B,dpH
   MUL AB
   ADD A,r2
   MOV r2,A
   MOV A,#0
   ADDC A,B
   MOV r1,A
   ret
Apakah gini yang dimaksud?
« Jawab #10 pada: Maret 24, 2011, 01:20:27 PM »
Kode: [Pilih]
bit 1–bit 0 or 1
sbit 1–bit 0 or 1
Wah...enak juga ya, kalo gitu.
Cuma sayangnya saya bisa nya cuma bahasa Assembler doang, itu juga masih belajar, belum mahir  :)
« Jawab #11 pada: Maret 24, 2011, 01:24:14 PM »
dan r0 di isi          FF
maka hasilnya r1=FE
                        r2=FF
                        r3=01
mul16x8:
   MOV A,R0
   MOV B,dpl
   MUL AB
   MOV r3,A
   MOV r2,B
   MOV A,R0
   MOV B,dpH
   MUL AB
   ADD A,r2
   MOV r2,A
   MOV A,#0
   ADDC A,B
   MOV r1,A
   ret
iya, seperti ini. terima kasih banyak. Mr joe.
Oia , saya nyobanya pake IDE+ simulator buat nulis program MCS-51, nama nya MicroV7.
