Penulis Topik: Sekilas Tentang Televisi Digital  (Dibaca 10528 kali)
Re:Sekilas Tentang Televisi Digital
« Jawab #15 pada: Agustus 22, 2010, 07:27:59 PM »
Banyak duren kali di Riau.... He...he..
Langsung di praktekin aja mas. Kata orang telkom streaming IPTV di PC minimum speed na 512 kbps. Via TV digital 4 Mbps.
« Jawab #16 pada: Agustus 22, 2010, 07:41:56 PM »
sini lagi musim nanas .... eh ngomong2 gambar apaan tuh ... gras...
garciass gathool
« Jawab #17 pada: Agustus 22, 2010, 07:48:54 PM »
tu gambar percobaan digital atv...he...he...he.mungkin digital tv mirip''yg kayak gitu ya?
« Jawab #18 pada: Agustus 22, 2010, 08:06:33 PM »
[quote author=G
« Jawab #19 pada: Agustus 22, 2010, 09:25:03 PM »
nyari mpeg encoder kit ntu susah bgt dimana yaa ???... klo yg build up banyak !, tv digital & tv satelit perbedaaanya di transmisi....... encoder na mah sarua wae
TANDBERG MPEG2 SD ENCODER
yg kyk gini mantep.... ni encoder biasa di pake sama stasiun TV buat uplink ke satelit....
nah kalo ini biasa di pakai untuk DSNG, dengan fitur yg cukup untuk di lapangan ....kualitas gambar biasa2 !....
« Jawab #20 pada: Agustus 22, 2010, 10:20:58 PM »
kalo ini ??? gimana ???
BLUE DIGITAL VIDEO 1HE
BLUE DIGITAL supports DVB-T/H or ATSC (8VSB) full mode implementation.
The version may change depending upon demand.
Very high modulation performance (MER, signal stability, shoulder level, low phase noise).
MFN and SFN operation.
Powerful Linear and Non-linear digital pre-correction.
Configuration software offers a simple, intuitive JAVA Graphic User Interface by USB connection.
Pressure encoder provides great accessibility for user/device interaction, resulting in extreme ease of use.
Total control thanks to microprocessor easily programmed from menu or via RS232 with all key parameters displayed on a wide-screen LCD.
Expansion slots to increase equipment potentiality: up to 2 Slot to add ASI inputs and 4 Slot to add Euro Cards like Pre-driver or Driver options.
TCP/IP and SNMP are available for optional telemetry control.
Built-in GPS Receiver, optionally available.
Compact and rugged, stainless steel chassis, in 1 rack unit
« Jawab #21 pada: Agustus 23, 2010, 12:40:44 AM »
nah ini lebih edun lagi dah ada RF modulatornya jadi gx usah pake RF modulator external !.... bisa dual modus ATSC & DVB-T..... klo untuk ATSC dipakai di USA & jepang ...... tapi di indo masi langka yg pake RVR untuk encoder na umumna TANDBERG.... Merk ERICSSON jg ada...banyak si tapi jarang setahu saya
mungkin bang isurganteng.. exiter RVR ini yg dipakai buat TV digital di jakarta & bandung
« Edit Terakhir: Agustus 23, 2010, 12:59:34 AM oleh lutfi »
garciass gathool
« Jawab #22 pada: Agustus 23, 2010, 01:27:56 AM »
wah.pada bikin ngiler deh.aku pernah baca di blog org luar ada yg ngtread bikin dvb-t pake vga biasa seperti yg kita pake dengan memasukkan file .bat yg isinya perintah konfigurasi tertentu.outputnya lewat pin 1 vga connector.katanya di pin 1 itu dah keluar dvb-t freq vhf low 76mhz.mau nyoba tapi blon punya set top boxnya.harga termurah set top box brapa ya.dan toko yg jual tapi deket2 jogja mana ya?
« Jawab #23 pada: Agustus 23, 2010, 01:59:55 AM »
bisa diulasin dikit tentang tu garc ..
« Jawab #24 pada: Agustus 23, 2010, 02:17:08 AM »
wah jadi seru neh .... ternyata emang ada yang coba pake vga ... pake ati radeon 9200SE dibutuhkan pixel sampe 4096x2048 dengan 8 bit per pixel ....
coba liat deh .. http://bellard.org/dvbt/
garciass gathool
« Jawab #25 pada: Agustus 23, 2010, 03:04:45 AM »
nah tuh.bang Izur malah dah dapet threadnya.kan tinggal umpanin ke filter vsb 76mhz.trus diconvert up ke uhf.lalu dikuatkan pake uhf transposer.dah jadi stasiun tv digital pertama di pekanbaru bang!
« Jawab #26 pada: Agustus 23, 2010, 03:34:04 AM »
hahahahah ... ngenyell .... bisa dikejar sama balmon ntar ... wwakakwkakwwak
« Jawab #27 pada: Agustus 23, 2010, 03:50:13 AM »
mantap gan !  ;) ;) ;)
bener kata gracias pakai LPF trus masukin ke UP CONVERTER ke band UHF  lebih mantap lagi tambahin HPA pake RD70HVF1 kan bisa kerja di band UHF
broadband lagi hoho :D :D :D :D :D :) :) :)....bwt percobaan mah di CH21 aja paling bawah di 470 MHz
pokona mantap ane jadi ngiler gan pengen bikin ! :) :) :) :D :D :D :D :D
haaaaaaaaaaaaaaaaaa :) :) :)
« Jawab #28 pada: Agustus 23, 2010, 04:06:32 AM »
eta jempol meni gede pisan . ... weekekwkewke thangks garc atas info na .. .bisa untuk praktek ...
garciass gathool
« Jawab #29 pada: Agustus 23, 2010, 04:17:35 AM »
ok bang.tapi jangan lupa donlut dulu si le
