Penulis Topik: EAGLE V 5.6  (Dibaca 24239 kali)
EAGLE V 5.6
« pada: September 28, 2009, 09:06:02 AM »
Iki software gratis tuk pcb juga dari CadSoft
Freeware
The EAGLE Light Edition can be used for free!
Limitations
The following limitations apply to the EAGLE Light Edition in general:
    * The useable board area is limited to 100 x 80 mm (4 x 3.2 inches).
    * Only two signal layers can be used (Top and Bottom).
    * The schematic editor can only create one sheet.
Apart from these three limitiations the EAGLE Light Edition can do anything the Professional Edition can do. You can even load, view and print drawings that exceed these limits!
The Freeware version of EAGLE Light adds these limitations:
    * Support is only available via email or through our forum (no fax or phone support).
    * Use is limited to non-profit applications or evaluation purposes.
What does "non-profit" mean?
The definition of non-profit is fairly simple and straightforward:
    * If you earn (or save) money by using the Freeware version of EAGLE Light, you have to register it.
This allows anybody who wishes to use EAGLE Light for their private hobby projects to do so. Also students can use this version for any educational projects. It is even ok to use this version in a commercial environment, as long as you just want to evaluate the program. As soon as you start using it for commercial projects, you will have to register it. As an exception to this, board manufacturers may use the Freeware Light Edition to generate production data (e.g. Gerber files) from board files they have received from EAGLE users.
How do I get it?
Follow these steps to install the free EAGLE Light Edition on your system:
    * Go to the Download area and get the file that contains the EAGLE program installation data for your operating system (Linux, Windows or Mac).
    * Install the file you have downloaded onto your system.
    * When you first start EAGLE, you will be asked whether you have a personalized license disk, or whether you want to run EAGLE as Freeware. To use the Freeware license select the "Run as freeware" button.
Is it really useful?
Maybe you think the limitations of EAGLE Light won't allow you to do anything meaningful? Well, take a look at this 68HC12 board, which does not exceed the capabilities of EAGLE Light (in fact you can do even bigger boards than the one shown there).
How can I register/upgrade?
If your application exceeds the non-profit domain, or if you prefer to have a printed manual, CD-ROM and full support via phone or fax, you can register your program copy and receive your own, personalized license file. Any files you have created with the Freeware version of EAGLE Light can be used with any registered version of EAGLE Light, Standard or Professional. So if your project exceeds the limits of EAGLE Light, you can always go to a higher level (and you only have to pay the difference between what you have and what you are upgrading to).
You can register your program copy for US$ 49.- (ask your local dealer for prices in your local currency).
If you need more power than the Freeware version provides, maybe our Non-Profit License can be of interest to you.
Copyright
The Freeware version of EAGLE Light is copyright protected software, ?2009 CadSoft Computer GmbH, all rights reserved worldwide. No part of the executable files that come with EAGLE nor the freeware.key file that implements the Freeware license may be altered in any way. CadSoft reserves the right to decide whether to continue this Freeware program with the future versions of EAGLE.
Downloadnya disinih ..... :
sindhu xitrol
Re:EAGLE V 5.6
« Jawab #1 pada: Oktober 14, 2009, 07:37:34 PM »
aku juga pake eagle, tapi yang persi 4.11, soalnya dikomputerku yang stabil yang persi itu...kalo persi 5.0 sering hang di komputerku.....nyoba persi yang ini ah, sapa tau gak hang....
Re:EAGLE V 5.6
« Jawab #2 pada: Oktober 16, 2009, 02:22:17 AM »
saia dah coba persi 5 di laptop butut hp saia ... spek intel pentium M 512Mb hardess 60Gb ... os Windows Xp  ngga da masalah tuh ...
Re:EAGLE V 5.6
« Jawab #3 pada: Oktober 16, 2009, 01:44:26 PM »
Di komputerku juga tidak masalah, pake pentium 4 1,7 GHz dan windows xp home edition.
sindhu xitrol
Re:EAGLE V 5.6
« Jawab #4 pada: Oktober 16, 2009, 04:14:07 PM »
udah diberesin, ternyata OS saya yang busuk, makanya hang mulu..... ;D ;D ;D
gogon
Re:EAGLE V 5.6
« Jawab #5 pada: Oktober 21, 2009, 08:24:03 PM »
kalo os busuk,,,pake dong software RISING PC DOCTOR
Offline rosedo
  • Tulisan: 22
  • Tegal-Kudus PP.
Re:EAGLE V 5.6
« Jawab #6 pada: November 06, 2009, 01:40:47 PM »
Aku pernah pake eagle lupa versi berapa,
ada masalah setiap design pcb saya save, file-nya gak bisa dibukalagi,
kata temen tu karena crack-nya gak dijalankan,
sy coba crack tetep aja akhirnya saya ganti pake PCAD.
walau sudah nyaman pake PCAD tapi sy masuh penasaran. mohon pencerahan ???
inna ma'al usri yusran
Re:EAGLE V 5.6
« Jawab #7 pada: November 06, 2009, 09:56:42 PM »
perasaan saia ini gratis. .. kok pake crak ? apa ada yang pro nya yak ?
Offline rosedo
  • Tulisan: 22
  • Tegal-Kudus PP.
Re:EAGLE V 5.6
« Jawab #8 pada: November 06, 2009, 10:46:45 PM »
sori, file .lic klu gk salah yg musti di apain gitu sy lupa
Re:EAGLE V 5.6
« Jawab #9 pada: November 07, 2009, 05:47:05 PM »
saia install udah langsung jalan ... ngga da di apa2in ...
sindhu xitrol
Re:EAGLE V 5.6
« Jawab #10 pada: November 17, 2009, 02:58:26 PM »
ini bisa run as freeware ato pake lisensi bro, kalo run as freeware biasanya board bidang kerja terbatas lebarnya.....
rubel
Re:EAGLE V 5.6
« Jawab #11 pada: Januari 04, 2010, 11:30:09 PM »
saya juga ada prog ini, tapi pas langkah otomatis bikin lay out PCB dari skema, jadi acak-acakan...
nyerah deh... saya pake eagle, tapi kaga otomatis2an...ada tutornya gak mas Isur?
SAM
Re:EAGLE V 5.6
« Jawab #12 pada: Maret 13, 2010, 03:18:23 PM »
Salam kenal untuk teman-teman yang tergabung dalam forum ini. Saya juga menggunakan Eagle tapi kendala yang saya temukan bahwa untuk versi download itu freeware dengan versi ligh edition , ternyata versi ini hanya memberikan ukuran board 10 x 8 cm. Kepada teman - teman yang tergabung mungkin bisa membagi program Eagle versi Profesional . Terima kasih
keong
Re:EAGLE V 5.6
« Jawab #13 pada: Maret 18, 2010, 08:59:42 AM »
nih 100%pro bebas virus dan spyware
----- MA'AF LINK UNTUK CRACK TIDAK DIANJURKAN-------- (Edited by : Marconist)
« Edit Terakhir: Maret 19, 2010, 02:41:25 AM oleh MARCONIST »
Re:EAGLE V 5.6
« Jawab #14 pada: Maret 19, 2010, 02:11:52 AM »
wah ... saia tak bertanggung jawab ya .. buat member yang berikan soft crack ato serial ... pm2 aja deh hal2 yang beginian ... ntar forum ne pulak yang kena getah na ??? please donk ya .. .
