Penulis Topik: PCB EXPRESS  (Dibaca 3145 kali)
PCB EXPRESS
« pada: September 28, 2009, 08:52:53 AM »
  • ini buat yang butuh software pcb yang gratis .... dan juga yang bayar :D
        Draw a Schematic
    > We recommend that you begin your project by drawing a schematic. While not required, it will save you time when designing your PCB.
    Drawing a schematic with the ExpressSCH program is as easy as placing the components on the page and wiring the pins together.
    The schematic can then be linked to your PCB file, so that the PCB knows what needs to be connected together.
        Design the PC Board
    > Designing 2 or 4 layer boards using the ExpressPCB program is very simple. Start by inserting the component footprints, then drag them into position. Next, connect the pins by drawing the traces.
    If you link your schematic file to the PCB, the ExpressPCB program will highlight the pins that should be wired together in blue.
    Instant Quotes
    > After completing your layout, you can determine how much it will cost and how long it will take to have your boards made.
    The ExpressPCB program displays the exact manufacturing cost by selecting the Compute Board Cost command from the Layout menu.
    Order the Boards
    > Now the fun part. You order your PC boards directly from the ExpressPCB layout program. Here is how:
         1.    Run ExpressPCB and select Order Boards Via The Internet from the Layout menu.
         2.    In the order form fill in your name, address, email address and the quantity of boards you need.
         3.    To pay for the boards, we bill your credit card the exact amount shown by the Compute Boards Costs command. But don't worry, we encrypt your credit card number, along with the entire order before it is sent over the Internet.
         4.    Press the Place Order button to submit your order. It is sent directly to the ExpressPCB server.
    Offline van
    Re:PCB EXPRESS
    « Jawab #1 pada: Mei 19, 2011, 07:45:27 PM »
  •  ide1 wah mantap nih gratis-tis cari1
    Offline soerdjanto
    • Tulisan: 110
    • jelas dan menjelaskan
      • infocus
    Re:PCB EXPRESS
    « Jawab #2 pada: Juni 01, 2011, 08:29:29 PM »
  • biarpun cuma pake file gratisan, tapi hasilnya cukup lumayan
    saya nggak mbingungin sampean
