Penulis Topik: 1 GHz Counter from pira  (Dibaca 9324 kali)
« pada: Mei 27, 2010, 11:25:13 AM »
  • This simple counter is useful for frequency measurements of various wireless equipments, especially transmitters, receivers and signal generators in VHF/UHF band.
    Features :
    Display range: 0,0 to 999,9 MHz, resolution 0,1 MHz
    Correct rounding, reduced blinking of last digit
    Over-range indication
    Fast measurement - short measuring period
    High input sensitivity in VHF/UHF band
    Switchable intermediate frequency offset for use with receiver
    Technical specifications :
    Supply voltage: 8-20 V
    Supply current: typ. 80 mA, max. 120 mA
    Input sensitivity: max. 10 mV in 70-1000 MHz range
    Measuring period: 0,082 sec.
    Display refresh rate: 49 Hz
    Schematic diagram :
    Parts list
    R1 - 39 k
    R2 - 1 k
    R3-R6 - 2,2 k
    R7-R14 - 220
    C1, C5, C6 - 100 n mini
    C2, C3, C4 - 1 n
    C7 - 100 u
    C8, C9 - 22 p
    IC1 - 7805
    IC2 - SAB6456 (U813BS - different pin layout, not tested, also maybe R1 value need to be changed)
    IC3 - PIC16F84A programmed + socket
    T1 - BC546B
    T2-T5 - BC556B
    D1, D2 - BAT41 (BAR19) - may be ommited
    D3 - HD-M514RD (red) or HD-M512RD (green), 4-digits multiplex driven LED display from HP, or four standard 1-digit LED displays
    X1 - 4.000 MHz crystal
    BNC input connector
    To use with a receiver as a digital scale, close the -10,7 pins.
    IC3 program download: countr.hex http://pira.cz/counter.hex
    Programmer settings: Oscillator: XT, WDT: on
    For additional changes (eg. IF frequency offset change): counter.asm http://pira.cz/counter.asm
    The SAB6456 description :
    The SAB6456 is a prescaler for UHF/VHF tuners. The circuit has an input frequency range of 70 MHz to 1 GHz, has high input sensitivity and good harmonic suppression. With lower sensitivity it's usable down to 3 MHz.
    The circuit comprises an input amplifier, a divider stage and an output stage. The divider stage may oscillate during no-signal conditions but this oscillation is suppressed when input signals are received. The voltage-edges of the output signals are slowed internally to reduce harmonics in the television intermediate frequency band.
    Kepada temen-2 yg pernah membuat frequensi counter ini, tolong disharing pengalaman dan saran nya. Soalnya aku lg coba buat. ( supaya bisa meminimalisir kesalahan dan buget tentunya  ;D )
    Salam.....
    Offline RADIO-SEMPRONG
    • Tulisan: 129
    Re:1 GHz Counter from pira
    « Jawab #1 pada: Juli 26, 2010, 12:32:02 PM »
  • Prescalernya tu lho.. Carinya dimana??
    « Jawab #2 pada: Juli 26, 2010, 12:37:39 PM »
  • Marconi glodok siap bantu , tp harga nya...... ?? .???
    Aku mentok di PIC nya...
    • Tulisan: 663
    « Jawab #3 pada: Juli 26, 2010, 10:34:02 PM »
  • PIC16F84A banyak juga di toko beng elektronik glodok !,...
    « Jawab #4 pada: Juli 27, 2010, 12:34:01 AM »
  • Bukan IC nya pak , tp downloader nya yg bemasalah. Gagal baca error , terus..... ..nyampe aku buat 2 buah RCD , eh ternyata com / DB 9... Mb ku rusak.... ..
    • Tulisan: 663
    « Jawab #5 pada: Juli 27, 2010, 02:56:48 AM »
  • oooo dikirain..... kalo cuma MB rusak mah banyak bro pentium 3 ato 4 yg bekas masih bagus2 di harco mangga dua !,....pentium 3 dibawah 100rb an pentium 4 150rb keatas....
    • Tulisan: 265
    « Jawab #6 pada: Juli 27, 2010, 08:05:09 AM »
    saya juga kebngungan carinya
    « Jawab #7 pada: Juli 27, 2010, 08:39:26 AM »
  • Marconi & hermes glodok siap bantu mencari.... ?.. ? Tp harga spesial. Kalo ngambil @5 pcs mungkin harga bs turun... .. he....he.. Belum tanya lg sich...
    • Tulisan: 129
    « Jawab #8 pada: Juli 27, 2010, 03:30:00 PM »
  • SAB6456 di ebay kira2 USD10 blm ongkir.. Mahal tuh.. Sy pernah denger 74F112 2 biji bs dijadiin prescaler 10 ya? Ada yg pernah coba? Soalnya kalo pake ini lebih irit, lumayan kan kalo bisa dipake sampai 300mhz..
    • Tulisan: 1136
    « Jawab #9 pada: Juli 27, 2010, 03:48:45 PM »
    kalau prescalernya diganti pake lb 3500 bisa ndak ya???? ::)
    • Tulisan: 129
    « Jawab #10 pada: Juli 27, 2010, 07:21:15 PM »
  • Emang lb3500 msh ada di pasaran? Kalo ga salah ic tsb devider 8..
    « Jawab #11 pada: Oktober 23, 2010, 06:13:50 AM »
  • sulit juga ya cari komponennya.... :-[
    « Jawab #12 pada: Januari 23, 2011, 12:16:06 PM »
  • saya kurang tertarik frekuensi counter dengan PIC meskipun bisa ringkas banget.
    « Jawab #13 pada: Januari 23, 2011, 01:39:43 PM »
  • klo macem ini,.......tertarik ndak ya,..... ide1,
    « Jawab #14 pada: Januari 23, 2011, 02:09:58 PM »
  • lha ini swr power meter + frek counter jadi satu tambah ruwet tambah ga tertarik.klo tinggal pakai nah itu lain ai hi hi hi
