Penulis Topik: transistor alternatif  (Dibaca 237214 kali)
« pada: Maret 30, 2010, 10:47:28 PM »
sumonggo
« Edit Terakhir: Oktober 24, 2010, 02:05:17 PM oleh ridho »
Offline dxdiag
  • Tulisan: 205
Re: transistor alternatif
« Jawab #1 pada: Maret 31, 2010, 07:36:24 AM »
emand udah pena nyoba skema sama dengan c1970 + c1971 cuman 1970 aku ganti c1162 & c1971 aku ganti c1969 tu kluar maksimal 6watt bro tp di satu tempat kalu frekuensi digeser rata2 dapat 3-4watt bro? katanya bisa kluar 8watt tuh gimana caranya bo?
Offline dxdiag
  • Tulisan: 205
« Jawab #2 pada: April 01, 2010, 05:44:03 PM »
bagi yang hobi ngerik ato sekedar usil cuap2 lewat fm
nih ada panel 2666
cuma di input 1162 bisa tembus 20 watt
panel nggak panas
di upload dong foto jadinya biar klu mo nyoba ada patokan ato contohnya. c2666 harganya kisaran berapa?
Offline radio_balap
  • Tulisan: 179
« Jawab #3 pada: April 01, 2010, 06:57:06 PM »
Alternatif transistor for VHF, LOW + MID Power Output
Transistor   Power    Gain   Voltage   Frequency    Mode
2N3375       10W      5dB      28V      400MHz       FM/AM/SSB
2N3553       2,5W    10dB      28V     175MHz       FM/AM
2N3632        20W     7dB       28V     175MHz       FM
2N3866        5W     10dB       28V     400MHz       WINTransceiver
2N3924        4W       6dB    13,6V     175MHz       WINTransceiver
2N4427        2W     10dB     12V       175MHz       WINTransceiver
2N5108        1W       5dB     24V    1200MHz        WINTransceiver
2N5109      3,5W     11dB     15V     200MHz        WINTransceiver
2N5421        3W       9dB    13,5V    175MHz        WINTransceiver
2N5913        2W       7dB     12,5V    175MHz       WINTransceiver
2N5943        1W       8dB     15V       400MHz       FM
2SC730      0,8W    10dB     13,5V    175MHz        FM
2SC1590       5W     10dB     12,5V   174MHz        FM
2SC1591     14W    7,5dB     12,5V    174MHz        FM
2SC1729     14W     10dB     13,5V    175MHz        FM
2SC1947      3W     10dB     13,5V    175MHz        FM
2SC1966      3W     7,8dB    13,5V     470MHz        FM
2SC1967      7W     6,7dB    13,5V     470MHz        FM
2SC1968     14W    3,7dB    13,5V     470MHz        FM
2SC1968A   14W    5,4dB     13,5V    470MHz        FM
2SC2053    0,2W   15,7dB    12V       175MHz        FM/AM
2SC2055   0,25W   15,3dB    12V     175MHz         FM/AM
2SC2056    1,5W      9dB      12V     175MHz          FM
2SC2078      4W      13dB     12V     100MHz          FM/AM
2SC2086    0,45W   13dB      12V     175MHz          FM/AM
2SC2092      4W      13dB      12V    100MHz         FM/AM/SSB
2SC2094    15W     8,8dB    13,5V    175MHz         FM/AM/SSB
2SC2237       6W    13,8dB     13,5V   175MHz        FM
2SC2314     1,8W     17dB     12V      180MHz        FM/AM
2SC2538     0,6W     10dB     12V      175MHz        FM/AM
2SC2539      14W    14,5dB    13,5V    175MHz      FM
2SC2695      23W     1,9dB     13,5V    520MHz      FM
2SC3001        6W     13dB      7,2V     175MHz      FM
2SC3017       1W      11dB      13,5V    175MHz      FM
2SC3018       3W      13dB       7,2V     175MHz      FM
2SC3020       3W      10dB      12,5V     520MHz      FM
2SC3021       7W     7,7dB      12,5V     520MHz      FM
2SC3022     18W     4,8dB      12,5V     520MHz      FM
2SC3103    2,8W     6,7dB       7,2V     520MHz       FM
2SC3104       6W     4,8dB       7,2V     520MHz       FM
« Edit Terakhir: April 01, 2010, 07:06:35 PM oleh LUE »
._|\______________,,________
./_==o _________/
...),---.(_(__) /
.//___///
______/
The Man Behind The Gun
« Jawab #4 pada: April 01, 2010, 07:03:07 PM »
wah gimana cara aplutnya aku nggak punya web
ajari dulu
nho
2666 harganya 55rb bos
bentuknya silahkan cari di mbah google
kalo pesen jangan lupa 25 % buat forum
aku minta jatah bensin aja 5 rb
ada lagi 2667
bisa smpe 30n watt max 45watt
bagus input kecil saja
kalo 2666 mak 30 watt tapi jangan kalo buat broces
asik tho
pENTOONg pENTOONg stop!
dari pada 46 mahal 250 rb dsni
hoho 250rbu banding 55rbu 5 kalinya tho
« Jawab #5 pada: April 01, 2010, 07:05:09 PM »
bung lue kasih harganya nho
biar tau transistor alternatif ato bukan
kalo mahal mah bukan alternatif namanya
Offline radio_balap
  • Tulisan: 179
« Jawab #6 pada: April 01, 2010, 07:14:57 PM »
Info harga tergantung dari penjualnya/tokonya, yg jelas harga rata2 dibawah TR yg biasa digunakan utk band FM. Kalo pengganti 1946 saya pake c2540/c2094 hrg cuma +/- 80rb. Dan seterusnya........
Monggo dipilih trs "hunting" mana yg murah....... :)
./_==o _________/
...),---.(_(__) /
.//___///
______/
« Jawab #7 pada: April 01, 2010, 07:40:31 PM »
ya diuraikan biar temen2 pada berminat
setauku 1947 harganya 55rb deh
tuh 2078 kan 10watt di 30mHz
coba liat datashett per transistor bukan ombyokan
2053 juga mahan 12 rb
2538 juga mahal disini 20rbuan
2094 juga mahal
2237 juga mahal 55rb dsni
trus yang alternatif mana??
kalo 2078 sih emang murah 6rb bisa 10 watt
dipilah2 dunk biar temen2 pada hanting  :-\
tank you
« Jawab #8 pada: April 01, 2010, 09:25:48 PM »
sory saya ralat 1947 50rb
2053 6rd
kalau 2078 60rd untuk mendapatkannya dimana. apa bisa sama kamu
« Jawab #9 pada: April 01, 2010, 10:37:59 PM »
c2540 brpaaan tuh .. tuk ganti 1946 ... wasik tu .. bisa keluar 40w .. kalo ja murah ......... ::)
Offline VPDX
  • Tulisan: 184
    • MARS TEAM
« Jawab #10 pada: April 02, 2010, 07:20:57 AM »
ajari dulu
nho
ada lagi 2667
asik tho
napa ngak boleh dibuat broadces?
I LOVE ELEKTRONIKA
Offline dxdiag
  • Tulisan: 205
« Jawab #11 pada: April 02, 2010, 07:31:59 AM »
wah banyak banget tr alternatifnya? tp serinya kayaknya sulit tuh dicari dikota2 kecil seperti mojokerto, klu di surabaya mungkin ada tp kudu ubek2 pertokoan gentengkali yg mungkin butuh 2hari untuk keliling2 gentengkali  :D
Offline VPDX
  • Tulisan: 184
    • MARS TEAM
« Jawab #12 pada: April 02, 2010, 08:46:02 AM »
Kalau pake fm radio yg ada di hp bisa nyampe berapa meter?
I LOVE ELEKTRONIKA
« Jawab #13 pada: April 02, 2010, 08:52:54 AM »
ter gantung antenanya ma ketinggian antena bro
20 watt pake hasler ketinggian 10 m yang pernah ku coba cuma 1 kota
kira2 diameter 5-6 kilo pake hp yang ada radionya
yang jadi masalah itu kotornya frekuensi fm disini
dah nggak ada sela
disini fm dah penuh
harus ngalahi salah satu
kalo emang niat bikin fm brocest mending model repeater aja
« Jawab #14 pada: April 02, 2010, 09:57:28 AM »
mau aku kalo 2540 harganya 80 rb
