Penulis Topik: Antenna for FM DXing (88-108mhz)  (Dibaca 10268 kali)
« pada: September 17, 2009, 03:41:31 AM »
Building Your Own FM antenna!
Make your own antenna for FM DXing (88-108mhz)
        This is a classic ten element design. I bought this antenna around 1970 and just retired it this spring. This is a Finco design. Maximum gain of this antenna was in the 9-10db range. Directivity is good and front to back ratio is alright, but not quite as good as the APS-13 or the Channel Master Stereo Probe 9.  Here are the specs, in case you want to experiment with the design:
        Boom Length: 120 inches  (302cm)
        Reflector Length: 70 inches (178cm)
        Dipole D1 Length: 60 inches (152cm)
        Dipole D2 Length: 46 inches (117cm)
        Director A: 47 inches (120cm)
        Director B: 47 inches
        Director C: 49 inches (124cm)
        Director D: 49 inches
        Director E: 51 inches (130cm)
        Director F: 51 inches
        Director G: 51inches
        Next, here is the spacing between elements:
        Length AB: 12 inches (30.3cm)
        Length BC: 12 inches
        Length CD: 12 inches
        Length DE: 12 inches
        Length EF: 12 inches
        Length FG: 12 inches
        Length G to D2:  12 inches
        Length D2 to D1: 17 inches (43.2cm)
        Length D1 to R: 16 inches (40.6cm)
        Dipole D1 has a shorting bar  10 inches (25.4cm) away from the boom on either side. Dipole D2 has a shorting bar 12 inches (30.3 cm) away from the boom on either side. The shorting bar is nothing more than a thin piece of aluminum which connects the upper and lower sections of the dipole on both sides of the dipole.
        Antenna connections. Dipoles D1 and D2 are connected as shown in the diagram. Looking at the diagram, the antenna connections are made at a point 5 inches (13cm)to the left of dipole D1, after which the wires cross and attach to dipole D2 on the opposite sides. These two wires should NOT touch.
        Finco also made a 6 element version of this antenna. Maximum gain was about 3 db less than the ten element design. Try building this antenna minus directors A,B,C, and D.
        Hints on building an antenna. The easiest way to find aluminum for the elements, etc is from old antennas you may find. Look for neighbors hooking up to cable and throwing away their TV antennas. Look for damaged antennas with one or two bent elements waiting for the trash collectors to haul them away.  If making a closed loop dipole is too difficult, make an open dipole (as Radio Shack does in their FM antennas). To connect the dipoles together, use solid guy wire from a hardware store. This wire is about the right size. Find a plactic rectangular block about 2 inches (5cm) long, and drill two holes about 1.5 inches (3.7cm) apart. Get two long screws, some washers, and connect the two wires to the plastic block. Add two more washers per side, another nut (or wingnut) on either side, and you have made it possible to attach your lead-in to your antenna.
        If you are low on cash but have access to some old TV antennas, trying making your own design using this design as an aid.
        Note: This antenna has been out of production for years and the company that manufactured it is no longer in business.
« Edit Terakhir: September 27, 2009, 07:41:35 AM oleh isurganteng »
Offline Cyber-Blue
Re:Antenna for FM DXing (88-108mhz)
« Jawab #1 pada: September 17, 2009, 05:10:18 AM »
wahh.. gambarnya ngk muncul nih Sur.. :(
« Jawab #2 pada: September 17, 2009, 05:51:10 AM »
sak ya ... segodang tu ha ...... :o
« Jawab #3 pada: September 29, 2009, 12:46:01 PM »
wah macem mane tu gambarnye tak tampak tuh
« Jawab #4 pada: September 29, 2009, 03:00:16 PM »
lah ... disini nampak kooo ...  :o
« Jawab #5 pada: Oktober 09, 2009, 04:50:10 PM »
KAYAKNYA TU ANTENA SEKTORAL YA......
« Jawab #6 pada: Oktober 09, 2009, 05:44:48 PM »
Kalau lihat struktur, dimensi dan coba saya simulasikan, kayaknya antena ini adalah Antena ZL, ditambahi Reflektor dan direktor; Coba perhatikan feed systemnya dan polaritas feednya serta jarak D1 to D2.....
Lhah ... ini ZL ....!
Gitu to .....
Kalau ZL, memang f/b rationya tinggi....
Kesulitannya adalah nge 'match' kan phasa di D2 supaya bisa mensuport D1 .....
CMIIW............  ;)
NC / SM
« Jawab #7 pada: Oktober 09, 2009, 11:45:41 PM »
yoi betul sekali mba .... ZL dasar na ...
Offline gce.asep
  • Tulisan: 65
« Jawab #8 pada: Maret 19, 2010, 12:12:26 PM »
apa reflektor nya buat variasi aja yah dah jelas  zl berarti dah ga usah pake reflektor lagi dooonk.
« Jawab #9 pada: Maret 20, 2010, 12:52:06 AM »
ya itu kan tergantung kebutuhan ... ne hasil googleing ... tapi saia masi penasaran ... perasaan ukuran zl ngga kaya gini de .. tuk element nya biasanya panjang pendek panjang pendek ... masi belum ada yang mo kasi skema zl 5 dan 7 element ... buku saia dah ilang ... padahal pada buku kecil ntu warnah merah jambu kalo tak salah judul na antenna vhf 2meter band ada zl 5 7 dan 12 elemet ... tapi ngga nemu lagi .. buku dah usang ngga terbit lagi kali ... kalo ada rekan punya skema tolong dong di post disiini ... kalo dapet dari buku warna merah jambu ntu yang genit hwahehwae ditunggu :(
« Jawab #10 pada: Agustus 29, 2010, 11:45:58 PM »
ai...ai...ai... nunggu juga nih ceritanya.... ;D
« Jawab #11 pada: Agustus 31, 2010, 09:39:09 PM »
Bro,
Saya ada buku lawas buanget, warna merah muda, judulnya Antena 2 meter terbitan Binatronika. Coba besok tak scan khusus yang ZL aja ya..
« Jawab #12 pada: Agustus 31, 2010, 11:46:50 PM »
wah ... mantap gan ... yang 5 ma 7 ya gan .. he sip ...
« Jawab #13 pada: September 01, 2010, 08:43:42 PM »
Ini bos, muga berguna, oiya salam kenal dari arema....
« Jawab #14 pada: September 01, 2010, 09:35:04 PM »
muhun gan ... mantep2 ,,, ngomong2 kontruksi yang 2x folded dipolenya gan ... sekalian sama itungan stub biar ada signal di ekor gan ... wah .. sori ngerepotin ...
