Penulis Topik: Promo Walkie Talkie/Handy Talkie Baofeng Murah dan Bergaransi  (Dibaca 345 kali)
Offline kiswaradotcom2
  • Tulisan: 19
« pada: Pebruari 23, 2017, 03:51:45 PM »
Walkie Talkie Baofeng BF-888S
[spoiler=Deskripsi]
Baofeng Walkie Talkie HT (Handy Talkie) BF-888S UHF 16CH Free Earset merupakan Handy-Talkie dengan berbagai fitur seperti FM radio, PTT (Push To Talk), Emergency Alarm, Torch LED Light. Handy Talkie ini didesain menarik, selain itu Handy Talkie ini dilengkapi dengan earphone, docking charger, dual band antenna, serta belt clip. Baofeng BF-888s ini siap menemani aktivitas outdoor Anda. Cocok untuk Anda yang bekerja di lapangan, pecinta Alam, maupun untuk keperluan komunikasi lainya.
DETAIL SPESIFICATION
Type : BF-888S Walkie Talkie
Material : Plastic
Quantity : 1pcs
Item Color : Black
Frequency Range : UHF 400-470MHz
RF Rated Power : = 5W
Channel Capacity : 16
Channel Spacing : 25KHz
Operated Voltage : 3.7 V
Battery Capacity : 1500MAh Li-ion
Battery Life : About 8 hours
Frequency Stability : ±2.5ppm
Communication Range : About 2-4km
Operated Temperature : -30°C-+60°C
Antenna Impedance : 50O
Size : 6*3.3*11.5cm / 2.4*1.3*4.5
HARGA PROMO : Rp.112.000
HT Baofeng UV-5R Dual Band VHF - UHF Radio FM
HARGA PROMO : Rp.315.000
HT Baofeng UV-82 Dual Band VHF - UHF Radio FM
[spoiler=Deskripsi]
Functions :
Frequency Range : 136-174 & 400-520MHz
Dual Band, Dual Display, Dual Frequency,Dual Standby
A/B band independent operation
128 groups channels storage
Shortcut menu operation mode
VFO & Memory channels scan
Emergency Alarm
Tri-color background light selectable
0~9 grades VOX selectable
PTT & ANI ID
FM radio & 25 stations storage
1750Hz Brust
Tone Time-out Timer
Channel Monitor
Battery Saver
Keypad Lock
Channel Step : 2.5 / 5 / 6.25 / 10 / 12.5 / 25 KHz
Low Battery Alert
ROGER SET
Emergency Alert
25KHz/12.5KHz Switchable
FM Radio (65.0MHz-108.0MHz)
Large LCD Display
LED Flashlight
Hight /Low RF Power Switchable
Voice companding
50 CTCSS/ 104DCS coder & tone searching
PC programmable
Wide/Narrow Band(25kHz/12.5kHz)
Transmitter time-out timer(TOT)
High/Low TX power selectable
Specification :
Frequency Range : 65-108MHz(FM Receive only), 136-174MHZ and 400-520MHZ (TX/RX)<br>
Channel No. :128
Frequency Stability : 2.5ppm
Antenna : High gain DualBand antenna
Operating Voltage : DC 7.4V
Mode of operation : Simple or semi-duplex
Antenna : SMA -Female
Earpiece / mic type: Kenwood Plug type
Dimension(W x H x D) : 132 x 60 x 35 mm (not included antenna)
Weight : 238g(including battery, antenna)
Power adapter
Input : AC100-240V, 50-60Hz;
Output : DC10V/500mA;
HARGA PROMO : Rp. 340.000
NOTE !!!
1. Harga Diatas belom termasuk ONGKOS KIRIM dari Yogyakarta.
2. Pict yang di tampilkan di atas adalah Real/Foto asli dari Kiswara
3. Menerima COD bagi wilayah seturan sleman yogyakarta
4. Reseller Wellcome bisa Dropshipping atau langsung pengambilan quantity dengan syarat dan ketentuan.
5. Barang Ready Stock, namun untuk menghindari update data yang terlambat maka silahkan menghubungi CP terlebih dahulu.
6. COD Hari MINGGU  ,Harap Pesan Dulu di hari SABTU nya
7. Bisa pesan Via Gojek
Info Stok & Harga Reseller
Bima
Call/SMS : 082227248333
WhatsApp : 087738029500
Telegram : 087738029500
BBM : 79A0DF2B/28C6C3F9
LINE : bimakiswara2
::: Suport Pengiriman :::
JNE | TIKI | J&T | PCP | POS | WAHANA | ESL | CARGO | TRAVEL
(Bisa Menyesuaikan selama bisa menjangkau)
::: Marketplace :::
TOKOPEDIA
BUKALAPAK
Official Website
Kiswara Technology [/size][/b]TERMURAH SE INDONESIA
