Penulis Topik: kontroler untuk MC145151, dan bisa juga dipake untuk veronika  (Dibaca 2050 kali)
« pada: Maret 11, 2012, 07:47:00 PM »
Codeing BascomAVR
Kode: [Pilih]
$regfile = "M8def.dat"
$crystal = 8000000
$hwstack = 32
$swstack = 10
$framesize = 40
Config Lcd = 16 * 2
Config Lcdpin = Pin , Db4 = Portd.4 , Db5 = Portd.5 , Db6 = Portd.6 , Db7 = Portd.7 , E = Portd.1 , Rs = Portd.0
Config Portb.0 = Output
Config Portb.1 = Output
Config Portb.2 = Output
Config Portb.3 = Output
Config Portb.4 = Output
Config Portb.5 = Output
Config Portc.0 = Output
Config Portc.1 = Output
Config Portc.2 = Output
Config Portc.3 = Output
Config Portc.4 = Output
Config Portc.5 = Output
Config Pinb.6 = Input
Config Pinb.7 = Input
Config Pind.2 = Input
Config Pind.3 = Input
Declare Sub Printlcd
Declare Sub Setmc145151
Const Minfreq = 8750
Const Maxfreq = 10800
Dim Eeromfreq As Eram Word
Dim Mainfreq As Word
Dim Isstereo As Bit
Dim Islock As Bit
Dim Flagset As Bit
Cursor Off Noblink
Cls
Mainfreq = Eeromfreq
If Mainfreq < Minfreq Then Mainfreq = Minfreq
If Mainfreq > Maxfreq Then Mainfreq = Maxfreq
Isstereo = Not Pind.2
Islock = Not Pind.3
Locate 1 , 3
Lcd "ATmega8  PLL"
Locate 2 , 4
Lcd "Controller"
Waitms 2000
Cls
Call Printlcd
Call Setmc145151
Program:
   If Pinb.6 = 1 Then
      Mainfreq = Mainfreq + 5
         Mainfreq = Minfreq
      End If
      Call Printlcd
      Call Setmc145151
   End If
   If Pinb.7 = 1 Then
      Mainfreq = Mainfreq - 5
         Mainfreq = Maxfreq
      End If
      Call Printlcd
      Call Setmc145151
   End If
   If Pind.3 <> Islock Then
      Islock = Pind.3
      If Islock = 1 Then
         Locate 1 , 11
         Lcd "  LOCK"
      Else
         Locate 1 , 11
         Lcd "UNLOCK"
      End If
   End If
   If Pind.2 <> Isstereo Then
      Isstereo = Pind.2
      If Isstereo = 1 Then
         Locate 1 , 1
         Lcd "STEREO"
      Else
         Locate 1 , 1
         Lcd "MONO  "
      End If
   End If
Goto Program
Sub Setmc145151
Dim Con As Byte
Dim Root As Word
Dim Subfreq As Word
Dim Temroot As Word
Dim Datapll(12) As Byte
   Subfreq = Mainfreq / 5
   For Con = 0 To 11
      Root = 2 ^ Con
      Temroot = Subfreq And Root
      If Temroot > 0 Then
         Datapll(con + 1) = 1
      Else
        Datapll(con + 1) = 0
      End If
   Next Con
   Portb.0 = Datapll(1)
   Portb.1 = Datapll(2)
   Portb.2 = Datapll(3)
   Portb.3 = Datapll(4)
   Portb.4 = Datapll(5)
   Portb.5 = Datapll(6)
   Portc.0 = Datapll(7)
   Portc.1 = Datapll(8)
   Portc.2 = Datapll(9)
   Portc.3 = Datapll(10)
   Portc.4 = Datapll(11)
   Portc.5 = Datapll(12)
   Eeromfreq = Mainfreq
End Sub
Sub Printlcd
Dim Strfreq As String * 5
Dim Comfreq As Byte
Dim Lenfreq As Byte
   Strfreq = Str(mainfreq)
   Lenfreq = Len(strfreq)
   Comfreq = Lenfreq - 2
   Locate 2 , 1
   If Lenfreq = 4 Then
      Lcd "FREQ   "
      Locate 2 , 7
   Else
      Lcd "FREQ  "
      Locate 2 , 6
   End If
   Lcd Left(strfreq , Comfreq) + "." + Right(strfreq , 2)
   Locate 2 , 14
   Lcd "MHz"
   Waitms 500
End Sub
End
Offline DhannyDhuzell
  • Tulisan: 14
Re:kontroler untuk MC145151, dan bisa juga dipake untuk veronika
« Jawab #1 pada: Maret 17, 2012, 08:07:54 PM »
maksudnya gimana ini gan .. sambil di kasih cara pengoperasiannya ... cari1
Offline Ayon
  • Tulisan: 108
« Jawab #2 pada: Januari 30, 2015, 06:39:58 PM »
ok sip mas pur apa sy bisa coba?
