Penulis Topik: sPlan 7  (Dibaca 2031 kali)
sPlan 7
« pada: Desember 15, 2011, 08:20:36 AM »
    sPlan is a software with already many thousands enthusiastic users. You need a software to design your schematic circuit diagrams easy and fast? You won’t get pass sPlan! No matter if you only want to sketch a little circuit diagram or if you need to design a big project with several pages.
    The new version 7.0 is the consistent further development of the reliable predecessor. Many new and improved features helps you to create your schematics easy and clean. Of course the new version is full compatible with its predecessors sPlan 6.0, 5.0 and 4.0. You can load and edit all files from these versions.
    With the free viewer-software everyone is able to view and print your circuit diagrams.
    A free demo version of the new version 7.0 is also available.
    As always, we have set great store of a logical and simple use of the software.
    With sPlan you will design your schematics even after a short time very easily.
    The handling of sPlan is really quite simple. The components can be drawn from the extensive library to your circuit diagram. A user definable grid-capture makes it easy to place and wire the components. You can move, rotate, shear or scale all elements on your diagram just like you want. You can group several components to simplify your further work. The usual clipboard-functions let’s you copy, cut and paste any sections of your diagram. Many special features like the automatic component numbering, the component-list function, the usage of variables, the component search or the linking-functions helps you to design your schematics. Even beginners will create perfectly designed circuit diagrams within minutes.
    Component library
    The well-sorted component library contains all you need to draw a clearly arranged circuit diagram. Diodes, resistors, switches, transistors, etc. Just drag the needed components from the library to your drawing. If there is still a needed component missing, you can easily create this component and add it to the library. You may even reorganize the complete library and create symbols that exactly satisfy your demands.
    You can adjust the appearance of the library, like the width or the number of displayed columns.
    You can also create new libraries, which are located on network drives, so that many users can use the same library.
    download : http://www.abacom-online.de/uk/html/updates.html
    Re:sPlan 7
    « Jawab #1 pada: Desember 15, 2011, 08:24:24 AM »
  • Desain skema mudah dengan sPlan 7, librari gak repot ada disampingnya.
    untuk donwload librarinya download di : http://www.abacom-online.de/uk/html/bibliotheken.html
    Jamu (PM ya)  piss1  :D
