Penulis Topik: Atlas DCA55 - Alat Ukur/Test Transistor n Semukonduktor Paling Canggih  (Dibaca 19390 kali)
Offline hexxer
  • Tulisan: 155
Mohon info n bimbingan dari sesepuh semua. Dah lama googling cari alat cek transistor yg mumpuni, pas ketemu dengan Atlas DCA55 langsung jatuh hati. Sampe hari ini mo beli terkendala teknis pembelian. Mungkin sesepuh disini ada yg bisa bantu untuk pengadaannya. Ato mungkin malah ada yg bisa bikin sendiri :D
Bisa dicek di http://peakelec.co.uk/acatalog/jz_dca55.html tuk lengkapnya, termasuk harga n cara ordernya
The Peak Atlas DCA
A fresh approach to component analysis has resulted in the fantastic Peak Atlas DCA, an intelligent, slim and invaluable tool. A world of detailed component data has never been so accessible.
Just connect your component any way round and press the test button. The Atlas DCA will then present you with detailed component information in concise, easy to read, scrollable pages. The displayed information will include: the component type, special component features, component pinout, and measured parameters (such as gain, leakage current, gate threshold voltages, volt drops etc...). No more searching through data books and catalogues in order to identify components and pinouts, the Atlas does it all.
Analysis Portfolio
It doesn't matter how you connect the test clips to the component, the Atlas can analyse a vast number of different component types including bipolar transistors, enhancement mode MOSFETs, depletion mode MOSFETs, Junction FETs (only gate pin identified), low power thyristors and triacs (less than 5mA trigger and hold), diodes, multiple diode networks, LEDs, bi-colour and tri-colour LEDs. It will even identify special component features such as diode protection and shunt resistors in transistors. For two-leaded components such as diodes and LEDs, any pair of test clips can be applied to the component any way round, the Atlas DCA sorts it all out for you.
Simplicity
There is no on/off switch, power is automatically turned on at the start of an analysis and then automatically turned off if inactive for more than 30 seconds. Each page of displayed information is presented in manageable amounts, with each page being displayed when you want it. If you want to concentrate on the "pinout" page then just select that page, you don't have to see information that you don't need.
The Atlas DCA Package
The Peak Atlas DCA is supplied complete with a long life battery, universal test probes and a comprehensive illustrated user guide. Furthermore, free and unlimited technical support and advice is available to all users by telephone, fax, email or our web site.
  • Tulisan: 430
Re:Atlas DCA55 - Alat Ukur/Test Transistor n Semukonduktor Paling Canggih
« Jawab #1 pada: September 26, 2011, 07:00:54 PM »
pembacaan nya sngat detil tuh om..sikat aja..tar keburu kluar versi baru..kmungkinan akan launching versi terbaru utk instrument ginian..jd sayang nih klo kesempatan wat miliki dca55 gagal..he he he he..tp sy lebih suka pke meter jadul om,,spt merek heles krn dah familiar kali ya..wkwkwkwk..btw antn jd barter sm sisa peninggalan bersejarah tempo hari om..?
Offline hexxer
  • Tulisan: 155
« Jawab #2 pada: September 27, 2011, 05:28:39 AM »
Barangnya dah dateng om pas lebaran kemaren.
Barangnya manteb abis, bisa cek polaritas TR, Mosfet, dioda, berikut parameter dalemanya
Yang sisanya kasih waktu aja om, ane sambil meluangkan budget, om juga sambil melist kebutuhan lain, Klo pake flange berarti tambah lagi tuh kebutuhannya hehehe
Offline RizQ
  • Tulisan: 130
« Jawab #3 pada: Oktober 06, 2011, 08:15:00 AM »
Mau buat sendiri ?
Ini dia linknya http://felezyab.persianblog.ir/ ...
Silakan terjemahkan pakai google
Untuk donlodnya bisa di http://www.4shared.com/photo/nQTfrwiz/Transistor_tester_using_ATmega.html
Monggo ...  ide1
Offline azhar cekden
klu mau beli ni alat berapa duit mas
gimana cara belinya
aku dah bikin pake atmega328 :-D
ini hasil screen shootnya, sory pake hape jd ga bisa nampilin gambar, mungkin om momod bisa nampilin potonya
https://m.facebook.com/maz.sirin/albums/10202321095534195/?refid=17
sumbernya dari sini
http://www.mikrocontroller.net/articles/AVR-Transistortester
Upload aja ke http://postimage.org bro cungkrinx
angka yg dilayar bagian bawah maksudnya apa kang n klo transistornya rusak penunjukan layar gmn, trims
Ngukur elko + ESR
« Edit Terakhir: Maret 30, 2015, 04:03:23 PM oleh cungkrinx »
