Penulis Topik: AM/FM Dual Band Radio Module TJ-Si4730  (Dibaca 4161 kali)
« pada: Maret 17, 2011, 03:43:39 PM »
Description
SI4730 chip
FM band (76-108MHz) and AM band (525-1710KHz) compatible.
Low noise, high sensitivity (2.2UV), anti-interference ability, fewer external components, small size
(11*11*2mm), extremely simple for use.
Built-in LDO power correction module, debug-free, low-voltage, low power consumption, wide power range(2.7-5.5V).
Phase-locked loop PLL frequency stabilization technology, DSP digital signal processors, digital FM ST decoder and digital frequency tuning function.
Built-in LDO power correction module. Debug-free, low cost, high performance-price ratio.
Advanced built-in VCO (Voltage-controlled Oscillation Frequency Synthesis), AFC (Automatic Frequency Control), AGC (Automatic Gain Control) circuit.
Programmable clock, digital volume control and noise suppression.
AM band support a wide range of ferrite rod antenna and loop antenna. FM support 10cm PCB board short antenna design.
General-purpose I2C (2-wire) bus control.
Intelligent firmware upgrade feature.
More Product Features
HS Code:     8501109101
Trademark:     TJ
Standard:     102bc
Productivity:     50000PCS/Month
Unit Price/Payment:     USD2.10/Piece
Origin:     Si4730
Packing:     100PCS/Bag Plastic Salver
Min. Order:     100
Transportation:     Express Company Hkbam,Hkram
Usage:     Am/Fm Receiver
Type:     Iic Control
Style:     Wireless
Export Markets:     North America, South America, Eastern Europe, Southeast Asia, Africa, Oceania, Mid East, Eastern Asia, Western Europe
Re:AM/FM Dual Band Radio Module TJ-Si4730
« Jawab #1 pada: Maret 17, 2011, 03:50:21 PM »
ada yg tau gak di indonesia mna yg jual modul2 receiver ini..
« Jawab #2 pada: Maret 17, 2011, 09:00:58 PM »
berkat kemajuan teknologi yang dahulunya sebesar kardus mie instan skarang bisa sekecil ini
« Edit Terakhir: Maret 17, 2011, 09:28:41 PM oleh trisno »
« Jawab #3 pada: Maret 17, 2011, 10:43:33 PM »
modul kcil ini spesifikasi'nya dah komplit, kwalitas audio & decoder stereo'nya gax kalah ama yg bntuk fisik'nya gedhe2  top1 ,hrganya pun gax sebanding dngan teknologi yg sekomplit ini.. kalkulasi1 yg single band aja cma 1USD, kebanyakan modul ini ada di dalam mp3/mp4 player, saya msih gunakan receiver ini untuk setting2 audio pemancar fm
« Jawab #4 pada: Maret 18, 2011, 06:30:42 AM »
yang di pasang di dalam HP apa juga seperti ini apa ya? nunggu1
saya lum pernah buka daleman hp/mp3 player yang ada radionya.
« Jawab #5 pada: Maret 18, 2011, 09:57:01 AM »
Di Hp juga ada kang ini schematic di NO*IA N'GAGE menggunakan TEA5767HN
« Jawab #6 pada: Maret 18, 2011, 10:11:14 AM »
DATA SHET :http://www.semiconductors.philips.com/acrobat_download/datasheets/TEA5764HN_2.pdf
Modul Ini misal di Bikin pakai LCD sama ATMEGA bisa gax ya?  ??? Mungkin temen2 yg bisa bikin2 HEX atu yg lain ada yg mau coba  :-\  :-\
Offline klaxon
« Jawab #7 pada: April 29, 2011, 09:37:00 AM »
Saya ada kang Hex maupun asm nya mungkin ada yang jual Modulnya.......
Offline Am@R
  • Tulisan: 72
« Jawab #8 pada: Juli 29, 2011, 01:51:42 PM »
wah hebat juga bisa AM/FM  top1
« Jawab #9 pada: Juli 29, 2011, 02:25:22 PM »
bisa japan band juga lho....
« Jawab #10 pada: April 06, 2012, 01:58:20 PM »
