Penulis Topik: Plug In WINAMP  (Dibaca 9767 kali)
Plug In WINAMP
« pada: Oktober 06, 2009, 11:54:01 PM »
Buat yang dah coba dan hasil oke ... untuk plugin win Amp tampilin disini yak :D
STEREO TOOLS V4.01
« Jawab #1 pada: Oktober 06, 2009, 11:56:23 PM »
SqrSoft Advanced Crossfading Output v1.7.6 for Winamp
« Jawab #2 pada: Oktober 07, 2009, 12:07:33 AM »
SqrSoft Advanced Crossfading Output is a Winamp output plugin that allows mixing audio files by applying a "crossfade". The crossfade is made by an engine that supports non-linear crossfades and automatic detection of the mixing point. All these features make this plugin the perfect tool for parties or small radio stations.
The mixing engine has a sound analyzer, which monitors the level at the beginning and end of each track, and adjust the mixing point to obtain perfect crossfades. It also has in its output stage a slot for a DSP plugin (to be processed after the crossfade), allowing the crossfade to be sent to a Shoutcast server, a Compressor or any other DSP plugin.
There are a lot of settings that define how the crossfade will be done when you press stop, seek, skip, or the track level.
downloadnya disini : http://www.sqrsoft.com.ar/downloads/sqracf-1.7.6.1180.exe
dulu saia make versi 1.72 itu sangat sample banget dan gampang settingnya ... trus ringgan kerja untuk processor komp ... ngga tau ne versi 1.7.6 ... karena saia suka yang sample makanya menggunakan versi 1.72 .. menurut saia sudah cukup untuk setting mix lagu yang suka ngaco seperti raduga .. .ato sejenisnya ...
kesimpulannya ... sip banget deh ........
SqrSoft Limiter v2.0 Winamp
« Jawab #3 pada: Oktober 07, 2009, 12:13:22 AM »
Winamp
This plugin is based on the model of an analog audio compressor, and simulates the operation of such equipment.
This kind of sound processing is very useful for normalizing the level of the audio files. It can be configured as a simple automatic control of gain, which will serve to dynamically adjust the level of amplification or attenuation as appropriate.
In addition to function as a dynamic audio compressor, can also be configured as a limiter, "cutting" the signal that is above a certain trigger level.
     Download
This version includes the following languages: English, Spanish.
Actual version: 2.0
File size: 45.2 KB
http://www.sqrsoft.com.ar/downloads/dsp_cmpexp.exe
sanggar
Re:STEREO TOOLS V4.01
« Jawab #4 pada: Oktober 08, 2009, 08:44:02 AM »
Thank Boss, lagi didownload nih.
Winamp Plug-in - MuchFX2 - The DSP Winamp Plugin Stacker
« Jawab #5 pada: Oktober 11, 2009, 12:31:09 PM »
Author's Comment:
MuchFX2 lets you stack several DSP plugins. It also runs Winamp 1.x DSP plugins under Winamp 2.x.Now with improved compatibility for ShoutCast!
- Marc S. Ressl
Staff Review:
Yes! Very handy to stack/chain several DSP plug-ins, for example...
Sending DSP effects out to a SHOUTcast stream. Recommended highly for people looking to be creative with their SHOUTcast streams. Updated version with improved ShoutCast compatibility.
Random Review:
WTF????????
The ONLY downfall to this plug-in is, no way to close it (hide) and non-skinnable...otherwise, kick butt job! I love it!! Wouldn't play my tunes without it, and you know what?......I don't.
- Randy Meyer, Jan. 21st, 2003
Offline 4ND1K
  • Tulisan: 37
    • RADNET
Re:Plug In WINAMP
« Jawab #6 pada: Oktober 11, 2009, 02:38:41 PM »
Adapt-X plug-in for Winamp/Windows Media Player
Adapt-X 3.61 is a DSP plug-in that allows you to use DirectX plug-ins with your favorite player*. With Adapt-X you can listen to your music with the same professional effects used in real-life recordings.
*Adapt-X 3.61 supports Windows Media Player 9 or later and Winamp 3 or later
Donwload disini
Bila kita punya audio editor yang support dx plugin atau vst plugin kita bisa memanfaatkan untuk audio processor kita.
  • Tulisan: 663
Re:Plug In WINAMP
« Jawab #7 pada: Oktober 12, 2009, 02:57:41 AM »
« Edit Terakhir: Juli 19, 2010, 11:47:45 PM oleh isurganteng »
  • Tulisan: 663
Re:Plug In WINAMP
« Jawab #8 pada: Oktober 12, 2009, 03:00:41 AM »
winamp radio scheduler bisa putar iklan otomatis bisa di tentukan waktunya!!
http://www.winamp.com/plugins/details/138768
« Edit Terakhir: Juli 19, 2010, 11:48:27 PM oleh isurganteng »
Re:Plug In WINAMP
« Jawab #9 pada: Juli 19, 2010, 11:34:26 PM »
Re:Plug In WINAMP
« Jawab #10 pada: Juli 19, 2010, 11:36:55 PM »
kalo lagunya ngga pake efek ato suara murni .. ilang abis tu suara penyanyi ... kalo ada effect ya effeknya dengar lah dikid .. tapi mayan lah ... he ..
  • Tulisan: 648
Re:Plug In WINAMP
« Jawab #12 pada: Agustus 20, 2010, 04:37:19 PM »
Kalau ini plugin untuk live streaming... Shoutcast source DSP plugin.
Offline Am@R
  • Tulisan: 72
Re:Plug In WINAMP
« Jawab #13 pada: Oktober 22, 2010, 07:45:40 PM »
Untuk Shoutcast source DSP plugin down load nya di mana ??
tak ada link nya ...  :-\
Re:Plug In WINAMP
« Jawab #14 pada: Oktober 22, 2010, 09:42:34 PM »
mantabs...bener nih..... 8)
